Old 12-06-2018   #21
zr1assassin
zr1assassin's Avatar
Default Re: Let's see some "tucked away 4 winter" pics 😭
Beautiful Z! And those wheels...really compliment the car nicely. (What kind of wheels and what sizes are they??)
They are racingharts, 19s all 4 corners
zr1assassin is offline   Reply With Quote
Old 12-06-2018   #22
zr1assassin
Originally Posted by Ccmano View Post
Your car looks great, luv the wheels. I know you like the lowered look, and to each his own, but for proper handling the rear is too low. These cars were designed to have about 2 degrees of rake back to front with the front lower. My guess is you’ll end up with more understeer this way. To get the most out of the handling the back needs to be raised a bit.
Like I said, if you like it that way, great! Just wanted to point that out.
H
: cheers:
Thanks and I agree, if you notice I have the front tires sitting up on 3" pads and that's why it's making the *** end squat like that in the picture. I use those so I can get a jack under the front when I want. When it's pulled off those pads the stance is pretty perfect
Old 12-06-2018   #23
Shrek
:cheers:
[B][COLOR="seagreen"]Shrek[/COLOR][/B]
[SIGPIC][/SIGPIC]
Shrek is offline   Reply With Quote
Old 12-07-2018   #24
BlackZR1
BlackZR1's Avatar
Originally Posted by zr1assassin View Post
Do you recall what the minimum height required was?
Originally Posted by BlackZR1 View Post
I'll check tonight when i get home but i have the Backyard Buddy and found that i don't need to go to the max height, 1 notch below is fine for me (5'6") to reach what i need without crouching.
As Bob said, raising the garage door tracks was definitely required.
My Garage is 10'-10" high but you could get away with 9'-6" if you don't use the highest lift setting. The car on the bottom is slightly taller than the Z (about 4' tall) and fits under the lift on one setting below highest.
I can send you my layout drawings if you are interested.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
Old 12-07-2018   #25
zr1assassin
Yes please
cdscheib@gmail.com
Old 12-07-2018   #26
I'm lucky don't have to put it away.. Cold and dry we ride!!
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
