Old 10-18-2018   #21
Karl
Karl's Avatar
Default Re: Aluminum flywheel.... new clutch?
I had the Fadanza 13lb flywheel in my '92Z I use to own with the same clutch. in my current set up I am using the same clutch again, just a different flywheel.
Centerforce # 381039
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 10-18-2018   #22
zr1assassin
zr1assassin's Avatar
How did that combo do?
zr1assassin is offline   Reply With Quote
Old 10-18-2018   #23
Karl
Karl's Avatar
It worked quite well. Never had any issues with slippage. Was a little on the noisy side.
I prefer this combo better, seems to not be as loud.
I use Amsoil synchromesh manual transmission fluid in both transmissions.
I do not know how much hp this set up is good for but it is working well in the '93 which i am guessing is 475 - 500hp at the flywheel.
Old 10-18-2018   #24
zr1assassin
Awesome! Flywheel✏centerforce clutch✏amsoil✏....what else do I need here?
Old 10-18-2018   #25
Karl
Karl's Avatar
I believe a set of special length bolts for the flywheel. While you are in there may want to replace the pilot bushing too.
Old 10-18-2018   #26
zr1assassin
I've seen something about the bolts, I think jerry sells them. Pilot bushing and I think that may be it....
That Centerforce # 381039 was a DF right?
Old 10-18-2018   #27
Karl
Karl's Avatar
They are ARP bolts. If you search the part number will pop up or ask Paul I think he knows it.
Yes everything is a direct fit, no problems at all.
Old 10-18-2018   #28
zr1assassin
I was looking and seen a 381039 and a DF381039
Old 10-19-2018   #29
Karl
Karl's Avatar
I did not use the Dual Friction clutch, just the standard 381039.
Old 10-19-2018   #30
zr1assassin
Hmmmmmm
