Old 10-04-2018   #21
Default Re: Courtesy lights not working...
Originally Posted by jpalmer1717 View Post
So you're saying the courtesy relay is on the passenger side under the glovebox carpeted area?
no driver side.. right of column, you need to remove the driver side lower carpet piece of dash, then the metal plate behind it
Old 10-04-2018   #22
jpalmer1717
Actually it was the third relay on the passenger side. As soon as I plugged it in, on came the lights! What a feeling!
jpalmer1717 is offline   Reply With Quote
Old 10-04-2018   #23
gtcollins@maxnet.co.nz
Thats great another problem ticked off the list
Sent from my SM-G960F using ZR-1 Net Registry mobile app
Old 10-04-2018   #24
jpalmer1717
Carnage..
Old 10-04-2018   #25
jpalmer1717
The second relay I replaced is the fog lights which are now working too!!
Old 10-04-2018   #26
That's ugly
Old 10-05-2018   #27
Flyman 27
Flyman 27's Avatar
What could possibly do that to an underdash relay?
Was it a flood damaged car?
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 10-05-2018   #28
what did the rest of the wiring look like? If those are on the passenger side, was the heater core ever replaced?
Old 10-05-2018   #29
jpalmer1717
Everything else looked like new. My guess is a direct spill through the glove box.
