Old 09-22-2018   #21
TX '90 ZR1
TX '90 ZR1's Avatar
Default Re: Fuel sending unit replacement for an accurate reading
Originally Posted by carter200 View Post
This is also a good time to think about changing out the plastic “y” for the billet replacement unit I machine. It will not break nor leak like the discontinued plastic one will. If interested contact me via email. Thanks for looking.
I'll second this!
I had a fuel pressure leakage issue that I finally traced to a small crack in the fuel sender/pump unit "Y".
Might as well eliminate a possible future issue while you are there.
Kenny
1990 #442
Old 09-24-2018   #22
Meanmyz
Meanmyz's Avatar
Originally Posted by Marc Haibeck View Post
I have been cleaning the fuel level sensor as a repair procedure for quite a while. Recently I have encountered two units that would not stop skipping resistance at less than 20 ohms. That's about 3 to 0 bars on the gauge. This can cause the nasty jump from 3 to 0 bars in just a few miles.
I'm using a Stewart Warner universal fit sensor and fabricating an attachment to ZR-1 sender assembly. It's a modern thick film design. I get them from Summit Racing. Number SWW-439363-D. $37.
Hi Marc,
Thanks for the information! With all of the info supplied here, I will troubleshoot and if it is the sender itself, I will keep this in mind as it would be the cheapest way to fix this issue. You have supplied a direct answer/solution to my question. Thank you!
Meanmyz is offline   Reply With Quote
Old 09-24-2018   #23
spork2367
Originally Posted by Flyman 27 View Post
You can buy the sending unit without the pumps, search around the net. I can't remembered where I ordered from.
I was told that the few gallons in the bottom of the tank prevents the fuel pumps from overheating.
When my gage says empty &n shifts in to reserve mode, I still have 4 gallons left. I was told that this was correct.
Not available without pumps, and hard to find period. The whole units are available about two places for 340-370 dollars.
I was told by a very reliable source (-=Jef=-) that the sender unit is the same as a standard C4. So you could find a deal on a standard C4 complete unit & swap the sending unit. That would be the least expensive way to get a new sending unit.
Priced a standard C4 assembly lately? Out of stock a lot of places and 150-200 for the assembly without the pump.
Old 09-24-2018   #24
Flyman 27
Flyman 27's Avatar
I've seen them for less than this:
https://www.ebay.com/i/351242969272?chn=ps
But Mark's idea of using a customized universal sending unit is great, should fit the bill for most of us if you don't mind a little work.
[SIGPIC][/SIGPIC]
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 09-24-2018   #25
Flyman 27
Flyman 27's Avatar
Mark,
Could you give us a little more info on what has to be customized in order to use the Stewart Warner sensor? Maybe a photo or 2?
It sounds like you have worked out the problem quite well.
[SIGPIC][/SIGPIC]
Cams by Pete
Old 03-04-2019   #26
kr1276
I ran into the same problem and have ordered the Stewart Warner unit to replace mine. Any pics or guidance would be appreciated. Thanks!
kr1276 is offline   Reply With Quote
Old 03-04-2019   #27
Jagdpanzer
Jagdpanzer's Avatar
Here is the one I converted to the SW sensor
Image1551752866.083346.jpgImage1551752891.701774.jpgImage1551752923.796872.jpgImage1551753015.250517.jpg
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-05-2019   #28
kr1276
Jagpanzer,
Sorry but open your pics for some reason. Would you please send them to my email
kr1276@aol.com
Thanks,
Keith
Old 03-05-2019   #29
Phil,
did you bend the float rod on the new unit? I assume that is to match the movement and position of the OEM one correct?
Old 03-05-2019   #30
Jagdpanzer
Jagdpanzer's Avatar
Yes, had to bend and shorten it some.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
