#21 |
![]() Join Date: Jul 2007
What do the fittings look like for the high side and low side, that will help to determine R-12 or R134a
#22 | |
Also trying do determine if I need a white or a black orifice tube. H ![]() Last edited by Ccmano; 07-20-2020 at 07:50 PM. |
#23 |
Gotcha as for the orifice tube. Which are listed for the car?
#24 |
All I did was replace O-rings, new PAG oil in compressor and different fitting for evaporator/dryer.
#25 |
The white tube is standard. It appears the black tube is an optional automatic adjusting tube for severe climates. Anybody ever use one?
H ![]() Last edited by Ccmano; 07-20-2020 at 08:24 PM. |
#26 |
Years ago I installed a severe climate tube in Hot PHX with R 12 worked fine, blew 38-40 degree air out, dont know about the color
#27 |
![]() Join Date: Jan 2021
As mentioned in another threat I my R-12 was drained during import into Europe. So now I need to switch to 134a as R-12 is illegal here...
However, reading through this threat left some confusion. Appreciate if someone can add some clarity on the following: - switches: it was said that R-12 high pressure switch will not operate correctly but can be adjusted by turning the adjustment screw 1/4 ccw. So no other switches or adjustments other than that needed, correct? - PAG oil: I'm an A/C dummy so sorry for that stupid question (I know there are no stupid questions but I think this one is...) but the oil is not only inside the compressor but the entire system, right? So, I need to remove the compressor from the car, drain it and also flush the rest of the system? However, in an case I can re-use the OEM compressor with no further modifications? - Orifice tube: do I need to swap it? If so, Rockauto lists a variety: *GM GENUINE 155151 {#03033879, 3033879, 3033879OEM} *ACDELCO 155754 {#19189768, 88919511} - "OE replacement" *ACDELCO 1550120 {#19189841, 89032868} - "Optional Automatic Adjusting Orifice Tube For Normal Climates Under 105 Degrees" *ACDELCO 1550122 {#19189843, 89032872} - "Optional Automatic Adjusting Orifice Tube For Severe Climates over 105 Degrees" Which one is correct? Germany is not a super hot place, however does the "hot climate version" maybe improve the cooling power? I heard that the ZR has it's limitations here... Will I need a remover tool to get the job done or will needle nose pliers work? I already have a new dryer on the shelf which I will install including some fresh O-Rings. Now I need to collect the rest and plan the actual work. Sorry for all these questions but as spare parts are sometimes hard to come by over here I became very careful to not destroy things due to stupid mistakes ![]()
ZR-1 #638/1991 |
#28 |
![]() Join Date: Sep 2018
I converted my 92, but it was not easy.
R12 switches and hoses are SAE threads (American). All switches and hose fittings for R134a are Metric. I bought entire new 95 R134a system; evaporator, condenser, dryer, hoses, switches. Took months to gather all the correct stuff. Took about a week of wrenching to get it done. The most difficult part to get was the hose set the attaches to the compressor. No one makes it and the hoses out there are all built incorrectly. Here are my build/problem threads http://zr1.net/forum/showthread.php?t=30711 http://zr1.net/forum/showthread.php?t=30748
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers 2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black 2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige |
#29 | |
H ![]() |
#30 |
![]() Join Date: Apr 2016
I don't know about the high pressure switch but the low pressure switch is adjustable by turning a screw between the terminals.
The low pressure cut off is 2 lbs lower for R12 than R134a but the switches are the same. If you buy a new replacement, it will be set for R134a. I'm still running R12 and I discovered this when I had to replace a faulty LPS. |
