03-08-2007 | #21 |
Re: opinions on this wheel
You could add a spacer to get the wheel/tire positioned correctly. I had to do that on my '70 when I switched to ZR-1 type wheels. They're a little tough to see in the picture below (click on it to see a bigger image) but in person they're fairly easy to spot. If all you need is an inch they would be almost invisible.
(click to see a bigger image)
[IMG]http://www.c3vr.com/member_uploads/401_500/419/thorsten_norge.gif[/IMG] [B][I]Jim O. [COLOR=white]..............[/COLOR][IMG]http://www.c3vr.com/forum/smileys/smiley27.gif[/IMG] [IMG]http://www.c3vr.com/member_uploads/401_500/419/driving1.gif[/IMG] "[COLOR=red]The Toys[/COLOR]" [/I][/B] ...'90 ZR-1.......'70 roadster.......'78 Trans Am.... [I][B][URL="http://www.c3vr.com/member_uploads/401_500/419/TheToyII_102_852.jpg"][IMG]http://www.c3vr.com/member_uploads/401_500/419/TheToyII_104_65.jpg[/IMG][/URL] [URL="http://www.c3vr.com/member_uploads/401_500/419/TheToy.jpg"][IMG]http://www.c3vr.com/member_uploads/401_500/419/Itsa70_36a2.jpg[/IMG][/URL] [URL="http://www.c3vr.com/member_uploads/401_500/419/PICT3106a.JPG"][IMG]http://www.c3vr.com/member_uploads/401_500/419/PICT3106a_sig.JPG[/IMG][/URL] [/B][/I] (click on each to see a larger version) [I][B][COLOR=red]Save the Wave...!!! [IMG]http://www.c3vr.com/images/smilesani/wavey.gif[/IMG][/COLOR][/B][/I] |
03-08-2007 | #22 |
I'd send them back and get the correct offset
03-08-2007 | #23 |
so 13mm difference will be about an inch to narrow? I don't have the wheels bought yet.
03-08-2007 | #24 |
the offset won't impact the width of the wheel, just how it sits on the car
03-08-2007 | #25 |
Ok , will a spacer really make it look correct, and is that safe?
03-08-2007 | #26 |
An inch spacer is pretty healthy...and you'll have to use longer wheels studs I would imagine. I would not opt for the incorrect offset wheels myself.
Uly Past OWNER 90 ZR-1 #0120 Red/Saddle UT Plate: EZR1DER |
03-08-2007 | #27 |
yeah I'm cooling on the idea ...damn! I guess I'll stick with my original older chrome and try and make 'em look nice.
03-08-2007 | #28 |
you can try and find some with the correct rear offset, or find stock oem ones and have them pced any color you want. I maybe talking to jeff when i get my next car
03-08-2007 | #29 | |
03-08-2007 | #30 |
easy to find.....expensive to buy ,close to 1500 just about everywhere for A molds...for 93 silver finish... next to impossible
