03-07-2007 | #21 |
Re: Spark plugs
NGK Irridium here too. They work great but, I'm running the TR7IX per Marc Haibeck. I assume that the only difference is the heat range.
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 |
03-07-2007 | #22 | |
Re: Spark plugs
Both are two ranges colder than the plugs NGK recommends for our applications. Did you simply overtighten the plugs to taper the seat on the head? I was leary of doing that and went with flat-seated replacements.
03-07-2007 | #23 |
Re: Spark plugs
I ended up going with the over-torque method. So far so good it's just that the car hesitates a little when cold. After it runs for five minutes all is well.
04-01-2007 | #24 | |
Re: Spark plugs
04-12-2007 | #25 |
Re: Spark plugs
has anyone tried the #5 acdelco?
04-13-2007 | #26 | |
Re: Spark plugs
As to plugs I have NGK's in now and have had the OEM's without noticing a difference. Mobil 1 filter and oil every 3k. |
04-13-2007 | #27 |
Re: Spark plugs
just make sure the anti-seize does not go in the combustion chamber...leave a couple of threads clean,because anti-seize WILL cause pre-ignition..
bj |
04-14-2007 | #28 | |
Re: Spark plugs
