05-30-2018 | #21 | |
Re: Slight surging while decelerating / coasting
H
05-30-2018 | #22 |
Hans,
I think he is describing a Haibeck prom on a Moates g2 adapter.
05-30-2018 | #23 | |
H https://www.ebay.com/itm/Haibeck-Tec...BZ5hcO&vxp=mtr
05-30-2018 | #24 |
Right. I can erase the original prom and burn it w a modified cal, although that is a PITA. Spoiled I guess w Ostrich.
05-31-2018 | #25 |
Mine does it too. Put Marc’s chip in in 2015 and it still does it but idles slow now and runs much cooler with ac on!!!
Jim 1990 Z # 2441 1959 c-1 230 HP 4 speed frost blue/silver 3 owner 2011 cts-v 556 HP, manual 6 speed 1955 chev 2dr ht PP 265 3 speed w/OD |
05-31-2018 | #26 | |
Sent from my XT1585 using ZR-1 Net Registry mobile app |
07-05-2018 | #27 |
This is what Marc Haibeck told me regarding this subject:
"Yes it is normal. It's more noticeable on some cars than others. It is the deceleration fuel cutoff mode activating when you close the throttle to coast. When the throttle is opened the fuel is turned on causing a small surge in torque. The deceleration fuel cutoff mode can be turned off in the engine calibration chip"
Roy Martin 1994 ZR-1 #112 Admiral Blue/Black Dana 4:10 Aluminum flywheel Corsa exhaust Watson headers Haibeck chip 470 HP/399 RWHP 1991 ZR-1 #400 White/Red (SOLD) Dana 4:10 Powder coated engine Haibeck performance chip Borla exhaust |
07-05-2018 | #28 |
I had a similar problem (2200 - 2500 RPM’s coming to a stop) and replacing the ICAC didn’t fix it. So, I sent the throttle body to Mark for a rebuild and also get his chip. He found some “gunk” behind the throttle body plates on the manifold side. It is unknown how it got on that side, but it caused the plates to stay partially open and the high idle during deceleration and coming to a full stop.
Lou
07-05-2018 | #29 | |
Steve, I locate the Ostrich up around the wiper motor. There’s a spot there where it tucks in nicely. I also put it in a ziplock bag to keep any moisture away from usb port. One other alternative is to remove the stock prom and solder in a EEPROM. I have the SST 27F512. This allows u to flash the cal without needing to UV erase things. I use the Moates Burn2 for this. However, to use the 512 chip, you need to “stack” the bin because its looking for a 64kb block not 32kb.
07-08-2018 | #30 | |
Sent from my QTAIR7 using ZR-1 Net Registry mobile app |
