#21 |
![]() Join Date: Jun 2013
Then how are the ECM's interchangeable as per Marc?
#22 |
![]() Join Date: Jul 2007
Because the OEM ECMs have enough inputs and outputs..
So the PROM then Defines the ECM's inputs and outputs. if you mapped it out the Power key, knock and EGR use pins that are unused on the 1990.. Functionality was there in the ECMs, just not used
#23 |
So one would think that would be even easier on the megasquirt ecu. Which begs the question, what is different on their ecu between cutoff. I sent them an email.
#24 | ||
![]() Join Date: Aug 2015
Sent from my QTAIR7 using ZR-1 Net Registry mobile app |
#25 | |
