#21 |
![]() Join Date: Oct 2013
Hans,
Did the cams for the first time last year using the updated instructions from Marc posted on his business site. Takes time but once one cam done, others follow quickly. Tony - Tnova |
#22 |
What would be helpful is if there was a video of this process. Haven’t found one yet.
H ![]() |
#23 |
![]() Join Date: Dec 2003
If you do decide to time the cams, by any method, you must replace the cam sprocket bolts. Quite a few engines have had major damage due to broken, OEM bolts which are torque to yield, one use only.
#24 | |
H ![]() |
#25 |
Yes, what Jerry said. I used the old bolts while timing the cams. Once the timing was set, installed the new bolts.
