Old 02-25-2018   #21
Default Re: Who has removed the fx3 Holstein shocks to lower
I did my own coilover kit, used a universal kit and a couple custom machined parts on OE replacement FX3 shocks.. here is the stance
Sent from my iPad using ZR-1 Net Registry
Old 02-26-2018   #22
zr1assassin
zr1assassin's Avatar
Looks perfect!
zr1assassin is offline   Reply With Quote
Old 02-26-2018   #23
Ronstar
I have fx3 and coilover as well. I had Haibeck do mine. Can’t remember the price but I thought it was pretty reasonable. Got mine considerably lower than the above picture. When I get home I’ll see if I can post a pic of the stance.
Love the ride and handling.
Ron Thompson
1990 421ci ZR-1
2010 ZR1 (stock)
Ronstar is offline   Reply With Quote
Old 02-26-2018   #24
zr1assassin
Did he just slot the factory shocks for springs?
Old 02-26-2018   #25
Yes. I actually had Marc groove my shocks for snap rings that hold the sleeve in place..
Outside of the relocation stuff, I have $500~ in my coilovers, not including shocks
Old 02-26-2018   #26
zr1assassin
That's not bad! Do you by chance have part numbers on what you used?
Old 02-26-2018   #27
I can look, it will be later tonight when I get back from work
Old 02-26-2018   #28
got a short break:
Purchased below from Speedway Motors, in 2009
4x 91046236-BIL (Coil over Kit, 5" sleeve, 2" body) $39.99ea
2x 44410-425 (425lb Hypercoil 10" Coil-Over Spring $59.99ea (front)
2x 44410-275 (275lb Hypercoil 10" Coil-Over Spring $59.99ea (rear)
Contact carter200 in this forum for pricing on:
Coilover Hat Offset Bushing
That is a key piece for the system I put together
so $400 from Speedway, I forget the price of Offset bushing ($125 at the time maybe?)
then the Sway bar and shock relocation (I used Carters rear kit since I had done the front already)
Fronts were done in early 2009, rear done in Jan 2010. I had to add a washer to the hat, but overall the setup works
Old 02-26-2018   #29
Mystic ZR-1
Mystic ZR-1's Avatar
Are the shock mounts up to the task?
With coilovers, they're doing a job they weren't
designed for..
Old 02-26-2018   #30
carter200
carter200's Avatar
Like Jeff said contact me if you need the items he mentioned.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
