Old 02-10-2018   #21
jss06c6
Default Re: High searching Idle
Originally Posted by Ccmano View Post
At the risk of stating the obvious. You checked both MAP sensors, right?
H
?? Hose under the ECM ?
Old 02-10-2018   #22
Ccmano
Yes, the other map sensor is under the ecm on the 90-92
H
Old 02-10-2018   #23
jss06c6
Looked at it Hans. No issues. I'll recheck to make sure hose is good.
Old 02-10-2018   #24
mike100
well, since you have eliminated the outside hose connections, it sure sounds like the hard plastic curly-q under plenum hose has popped off. It goes to the gas tank purge solenoid. The leak is big enough to idle at 1200 rpm as you described. My car came like that and was the reason for my first plenum pull.
Old 02-10-2018   #25
jss06c6
That's my guess too after reading Marc's summary of known offenders! Will know this afternoon when I get under there with my borescope..
Old 02-10-2018   #26
jss06c6
Found it.. unfortunately. Borescope clearly shows the hose on the curved pipe under the TPS going to the gas tank purge solenoid is off. Backfire must have blown it off. Will put hose clamps on these hoses when im in there this time.. happy I found it and glad it's not the TB. Well, needed to pull plenum and IH's to Port them anyway!
Old 02-10-2018   #27
... happy I found it and glad it's not the TB. Well, needed to pull plenum and IH's to Port them anyway!
The Lord works in mysterious ways.
Old 02-10-2018   #28
Ccmano
Glad you found it, Had to be something related to the backfire. Unlikely the throttle body would go that suddenly.
H
Old 02-10-2018   #29
jss06c6
Indeed!
Old 02-10-2018   #30
jss06c6
H
More labor, but easier fix!!
