Old 02-05-2018   #21
efnfast
Default Re: Tranny drain plug
Oklahoma is no where near Dunbarton....
Not geographically, but trying to keep it in the family.
Old 02-05-2018   #22
efnfast
So, I went to VW, without a part number. Ask the counter guy for a drain plug for a ZF tranny. The guy asks what it is for. I tell him my Vette. He look at me and says "your at VW". I kinda explain, gets me nowhere.
I go down to Chevy, had already checked on line and know they no longer support it. Guess what they tell me. We no longer support that.
I had called Doug to check the forum for a VW part number. He tells me 100-937.
Back to VW. Different parts guy, I give him the part number, he says "that's the wrong number, it's a 001-937, drain plug for an old ZR tranny". Where was this guy the first time I walked in??
So, I took 1 and ordered 3 others.
Now I just need to get the old one out.
Thanks everyone for the help and advice.
Old 02-05-2018   #23
Demps
Demps's Avatar
In addition to all of the others: I've had success using aluminum foil between tool & plug if plug is/was 'boogered' up. I'll take a very large crescent adjustable wrench (harbor freight) and position it on bit right at plug.
Ted
Old 02-05-2018   #24
efnfast
Thanks Ted, I'll try the foil trick, the socket is kinda' loose.
Old 02-05-2018   #25
WVZR-1
I doubt you can blame the VW counter guy! You certainly could have taken either the part# or the image with you.
Old 02-05-2018   #26
garyhugo
garyhugo's Avatar
Steve, If all else fails I used a small pipe wrench(new) with sharp teeth and it grabbed the plug and turned it.
Gary
90-1572
garyhugo is offline   Reply With Quote
Old 02-07-2018   #27
efnfast
Got it. Heat on the case, floor jack under the socket to hold it tight in place.
Old 02-07-2018   #28
jss06c6
Holy cow that thing was seriously locked up! Glad you got it out.. Certainly recommend teflon sealer when you reinstall it..
Old 02-08-2018   #29
efnfast
I taped it with Teflon. The floor jack worked great, I just put a little pressure on the bottom of the ratchet to hold the socket tightly in place. Installed my new VW plug, waiting for more so I can also replace the fill plug (which I've already broken loose).
Old 02-08-2018   #30
efnfast
Picked up three more plugs today.
The part number from VW is WHT 001-937
If anybody is in need, I have two extras.
