Old 02-12-2018   #21
Default Re: Need Help Diagnosing This Sound
wow to me it sounded like the rear axle hub was bad. Bolt it up and let us know
Actually, I'm still battling a significant problem on this one!
After I got the lugs all tightened up I wanted to do more testing -- rotated all 4 wheels by hand when it was on stands. No noise. Problem solved, so I thought.
When I take it off the stands and move the car back and forth -- ca-lunk!
I'll get another video...
Old 02-12-2018   #22
lfalzarano
Just thinking, with no load on wheels, bearings and suspension no noise and then load is applied??? When you had it on jacks, did you check the other areas or stopped, assuming it was the loose lug nuts?
Old 02-12-2018   #23
Did not check other areas. I'll get it back up on jacks after I get a new video...
