01-31-2018 | #21 |
Re: 92 LT5 ecu ignition program and control
Pic of the injector bosses intrusion into the port
01-31-2018 | #22 |
Pic of custom pipes
02-01-2018 | #23 | |
02-01-2018 | #24 | |
Do you know if the knock sensor if left wired to the ecu would continue to help retard ignition if there was a condition of too much advance in the timing . |
02-01-2018 | #25 |
If there’s knock, then the ECM will retard timing depending on the amount of retard defined in the calibration. Given that the ECM is calculating pulse width to control injectors, doubtful u can use the OEM ECU. A Holley Pro-Jection system may be a viable alternative.
02-01-2018 | #26 | |
Basic question is if I removed all injector wiring and map sensors ,TPS, 02 sensors, coolant temp etc etc but left ignition sensors like crank sensor and knock sensor would the ecm still carry out the ignition function when over the 400rpm ? |
02-01-2018 | #27 |
Ignition is controlled by the ECM and is based on RPM x MAP. Without sensors, u have a bunch of codes. Whether the motor would even start is questionable. It certainly would be in “limp home” mode. What u are describing is using an ignition control system, so that’s what u should use.
02-01-2018 | #28 |
One other point about employing carbs sitting on top of the LT5 plenum. The plenum and injector housing was designed as a dry induction system for port fuel injection. Quite a few twists and turns in the journey of air from TB to combustion chamber. Runner length is quite long. I can see quite an issue with fuel coming out of suspension in the induction tract and dumping raw fuel onto the valves. Don't mean to rain on your parade, but I don't think its a very workable configuration.
02-01-2018 | #29 |
Dam Id forgotten about the limp home factor .
Will do some more thinking. |
02-01-2018 | #30 | |
If you're going carbs, I'd do a custom tunnel ram fabricated manifold.
Todd ____________________________________ *** our email address has changed! info@pepmeierengines.com pepmeierengines.com Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384 Pepmeier Engine Development |
