#21 | |
![]() Join Date: Nov 2016
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker [SIGPIC][/SIGPIC] |
#22 |
Question.... My guess is that the new wheels will require a sensor so that the tire pressure will work.
Will the "new" style (built into the stem) work or does it require getting the "wheel band" style. ( I HATE the wheel band. No matter how many times I warn the tire guys, they always jack one of them up).
#23 |
![]() Join Date: Jul 2007
For the stock system to work you need the stock sensors. The new style is totally different technology. Or if you are creeping the original wheels just skip the sensors, I don’t have them on my car any longer
#24 |
![]() Join Date: Nov 2011
Without the sensors, the LTPWS will not go off.
When I did mine, I used a Dill stem style. It gives me actual pressure in the tire and temp. The problem is, what to do with the readout. It needs to be mounted somewhere. |
#25 |
![]() Join Date: Oct 2004
Yours doesn't have an iOS or Android relationship so you can use a phone? I doubt the necessity of 'always on/always to be seen'.
#26 | |
When you warn the tire guys you need to be visual or at least give them a clue. 20 yo men have no clue what this 28 year old tech looks like or where for that matter it is on mounted on the wheel. I bring in a used tire band and sensor to show them what it looks like. I explain where it is mounted in the center of the rim inside the wheel. That the sensing unit head is exactly 180 degrees from the valve stem so they know where to break the tire and go slow. Works like a champ last time I went to discount tire the manager stopped the guys "the entire crew" to give them a show and tell and afterword several of them watched the tech break the tire. Since I go to Discount repeatedly I am referred to the tire band guy with the old vettes. This 28 year old tech rarely fails unless you strip or track your car. Become your own advocate for your car. Show them how the e brake releases. Be vocal share your hobby. GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-28-2018 at 12:10 PM. |
#27 | |
No, I don't leave mine on all the time. I usually plug it in, check it, and put it away. |
#28 | |
![]() Join Date: Jul 2012
I have no sensors in my wheels and no lights on the dash. |
#29 |
Only 90s and 91s you can pull all the bands and no light will illuminate. MY 92-95's if you pull the bands you need to plugs the light bulbs behind the DIC or go with the electrical tape over the light method if you don't want to see the error lights
#30 |
Is this what you are looking for?
https://richmond.craigslist.org/wto/...460398815.html |
