Old 12-11-2017   #21
Default Re: Neat Cluster Alternative
Originally Posted by jss06c6 View Post
Well dang it Dominic! Impressive and very promising. Would be great to get DIY guys together with these guys since they seem to the ECM/CCM communications figured out.. I'll jump in with support. Would love to have HP Tuners again with my LT-5. Comfortable with TunerPro RT and Craig's box for sure, but this would be a nice step up..
He doesn’t need the DIY people. His system would run our motors using an LSx PCM. And it would support waste spark or CnP in addition to having full comms w the CCM.
Old 12-11-2017   #22
jss06c6
16 injectors and secondaries as well?
Old 12-11-2017   #23
Why would that be an issue? U need 8 injector drivers plus a ground to energize
the secondary relays. The 411 has plenty of room for programming to run our motors. And basically, the LT5 ECM is a glorified L98 calibration.
Old 12-11-2017   #24
jss06c6
Defer to your experience. I guess in my ignorance I thought the LT-5 required control of 16 injectors versus 8 in the LT-1 & LT-4.
Old 12-11-2017   #25
Nope. Only 8 injector drivers. The secondaries are driven by the secondary relays and use the primary injector signal to fire.
Old 12-11-2017   #26
yes, but the secondaries work in parallel with the primary per cylinder.. The Duty cycle is cut in 1/2 when all 16 injectors are energized I believe.
It would be cool to have OBD2 features on an OBD1 car..
-=Jeff=- is online now   Reply With Quote
