Old 08-28-2017   #21
cbaclawski
Default Re: Make into Track Car, or sell along? advice?
Originally Posted by VetteFantasy View Post
Here's another vote for tracking it! Sounds like there's not much left to do to get your car ready. I think you'll have a blast in it, honestly. I'm doing my first HPDE with mine in two weeks at VIR. Yesterday my husband and I were there for the IMSA race and I did the parade laps to practice for it. Wow, my appreciation and enjoyment of the car just skyrocketed! It felt so stable even blasting down the back straight. The previous owner totally track prepped it and traveled to many tracks along the East coast with it.
I really don't think you'd regret doing it. Randy Rippie of DRM is a great resource for track stuff, too, and he lives in NC. I'd be happy to share his contact info and I know he'd be more than happy to give you some advice.
Here's a pic of mine from yesterday. Look closely and you can see the roll bar! Even in a sea of 200 Vettes, it gets lots of admiration and attention. You just don't see them very often!
Its a done deal... going to the shop next week. Hope to see some of you guys on track someday soon (as you point me by )
cbaclawski is offline   Reply With Quote
Old 08-29-2017   #22
tnova
Big John,
I've a '91 ZR-1 that I'm preparing for autocross and an occasional track day and have been debating about what to do with seat in order to use a harness. Your seat is a perfect solution. What year is your seat from? Could you describe the mods a little bit more since it's not only the sub strap but the shoulder strap pass through that you had done. BTW I track a brand "P" in time trials about 6 times a year, full on track car that was a former club racer with a Momo seat and 6 point Schroth harness and I wear a HANS (required for my class). I'd never go on the track without a 5 or 6 point. Too many situations where staying firmly planted in the seat was the difference between maintaining control and losing it.
Tony -Tnova
tnova is offline   Reply With Quote
Old 08-29-2017   #23
BigJohn
BigJohn's Avatar
Originally Posted by tnova View Post
Big John,
Tony -Tnova
My seats are 95 sport seats.
Callaway Cars sent them to an upholster for modifications and custom hides.
Old 08-31-2017   #24
RussMcB
Originally Posted by cbaclawski View Post
I had an instructor last season whose real job was an emergency room surgeon. He was adamant that he would not ride in a car with a 4pt harness, on the track or otherwise..(though he was ok with stock 3pt)
I stand corrected. I did a little research and, it seems that while a 4-point is good for holding you in the seat (like, for autocrossing), sub strap(s) is still better crash protection, because the shoulder belts will still want to pull the lap belt upwards.
Thanks for poking me into rethinking my opinion.
Old 09-10-2017   #25
cbaclawski
Thanks to all that replied, I'm sold, car is going to the race shop Tuesday.
Here's what I plan to have done:
Definite:
1.) Seats/harnesses attached to a harness bar. Decided against a cage since I don't want to destroy the interior(want to run the zr1, not just another stripped vette)
2.)brakes - already have upgraded rotors and steel lines, probably just switch pads
3.)new radiator (car runs a bit hot)
4.)tires - would appreciate some input here, stick with stock width's or square it up, if changing what should I change to?
5.)basic maintenance - thoroughly check everything(no leaks, fuel pumps, injectors, etc...)
maybe:
1.)suspension upgrade, depending on what the shop reports on the condition/quality of what I have, might make an upgrade here. What would be a good choice?
2.)remove secondary intake system - I've checked that it's functioning properly, but it bothers me and would like to remove it as a potential failure point(and tired of constantly worrying that it's not working, I'm a bit paranoid. (if we do this, we'll change the plug wires while under there - coils and injectors are new)
3.) cool looking wing on the back!
Not being a mechanic or a super experienced track driver I know I'm probably overlooking some important stuff. Not really looking to add HP(plenty of that already) My priorities in order are Safety, Reliability, Performance, Cool looking.
I'd love to keep the total cost under $10k (probably already at $3500 with just seats harnesses and tires) Recommendations?
Curt
Old 09-10-2017   #26
ssrszz4
Get the Dewitt radiator
ssrszz4 is offline   Reply With Quote
Old 09-10-2017   #27
cbaclawski
this one?
https://www.dewitts.com/collections/...minum-radiator
Old 09-10-2017   #28
lbszr
lbszr's Avatar
Curt
The 315s square make it handle great. It's easy to overdrive the 275s. The 315's will balance it. The 56mm offset 17 inch wheels will fit the front and the rear with spacers and can be rotated. They will rub some on the front. If your used to using Rs, the Hoosier R7 are good. The NT01 are ok and seem to last longer, but they won't stick as much, I stopped getting them because the price went up to about Hoosier cost. I went with VBP extreme springs and sway bars. It was good improvement. I wouldn't recommend the R7 or nt01 if you drive to the track.
They like to eat wheel bearings so spares are nice. Also, inspect the bearing flange radius for cracks. Mine broke a flange off and the caliper held the wheel on, luckily I wasn't in a hard turn when it made the bang. This summer, another front flange cracked all the way around but didn't break yet. I check them before each event. The rear bearings don't seem to have these problems.
I run the Dewitts. It runs about 210 and oil temp is my limit. Oil will peg if no short shifting. Outside temp was 95 though. 75 to 80, it will make the whole session with no short shifting.
Old 09-10-2017   #29
lbszr
lbszr's Avatar
I think mine is the 2 row. I remember it was over $500. There wasn't a 1 row option when I got mine. I don't know which one would be better. I would give them a call.
Old 09-10-2017   #30
henryr
the "normal" 17x11 (56et) will fir up front ?
u have a pick of what that looks like ?
henryr is offline   Reply With Quote
