07-17-2017 | #21 |
Re: Antenna Mast and Grommet
07-17-2017 | #22 |
Not funny. Relative location of antenna on standard vette vs. ZR-1 is different. Top of grommet for ZR-1 is near perpendicular to the vertical neck. Standard vette grommet is at an angle relative to vertical neck. Gurantee you that standard grommet will not work on our Zs.
07-17-2017 | #23 | |
You are correct. The standard grommet is angled slightly back about 33 Degrees. The ZR-1 Grommet is vertical as is the mast.
07-17-2017 | #24 |
I used the standard and ground it flat, so its almost good enough but not really, because it is also smaller in diameter. But if you do this it will at least protect the antenna and not stick up above the fender.
The are ABSOLUTELY NOT the same part.
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI. |
07-18-2017 | #25 |
Ok, does the antenna come out of quarter panel or bumper?
It has been so long since my Z had an antenna that I don't remember! I have my stock bumper some where. |
07-18-2017 | #26 | |
Quarter panel and it's easier with the rear wheel off Sent from my iPad using ZR-1 Net Registry
