View Poll Results: At approximately how many ZR-1 miles before solenoid failure resulting in overhaul?
25 to 30k miles 1 7.14%
30 to35k miles 1 7.14%
35 to 40k miles 0 0%
40 to 45k miles 2 14.29%
45 to 50k miles 1 7.14%
50 to 55k miles 1 7.14%
55 to 60k miles 0 0%
60 to 65+k miles 8 57.14%
Voters: 14. You may not vote on this poll
Old 07-02-2017   #21
Default Re: Poll: How many miles before solenoid failed?
Originally Posted by bhedberg View Post
The problem I had was the female connector on the purple wire that connects to the starter. The metal in the connector is bent to produce a spring action against the male spade connector on the starter when it is plugged in. Over time, and in the harsh environment of the valley, that metal clip loses its spring tension and does not maintain reliable contact. When I opened up the plenum and disconnected the purple wire, there was no resistance at all to the connector coming off. That could explain the no start when hot and then starting again after partially cooling off. The metal clip can be released from the plastic of the connector and re-formed (bent) to reestablish some spring tension in order to provide a positive connection. As a backup, I always carry a "starter stick" I got from Gordon years ago. It is a 3/16 inch steel rod about 30 inches long. When experiencing the no start, the rod can reach the starter with the hood up and probing behind the engine at the firewall. The method is to hold the key in the start position and tap tap on the starter with the starting stick. (easier with 2 people) The vibration from the tapping can reestablish contact and get the engine started. Release the key to the on position after it fires up. Of course there are other failure modes that produce the no start condition but I'd guess there have been lots of perfectly good starters tossed because of the connector. Some may have replaced a starter only to have the condition return soon after.
That is a very good point! Thanks for posting this!
Old 07-02-2017   #22
gtcollins@maxnet.co.nz
My ZR-1 had less than 24000 miles on it when I pulled the starter Glen Collins
Sent from my SM-G930F using ZR-1 Net Registry mobile app
Old 07-02-2017   #23
KFoster
57000. Working on it now with some paint and porting. Maybe not such a good design. And that's being polite.
1990 ZR1, 1987 Mustang GT (since new), 1973 DeTomaso Pantera, 1987 928S4
Passed on: 1984 930S (gray market), 1988 Mustang Coupe Trooper car(drag)
KFoster is offline   Reply With Quote
Old 07-04-2017   #24
RICHARD TILL
80k and 119k on my 90 #2161.
Old 07-04-2017   #25
Wow! That early!
Well, Glenn, go ahead and place your vote in the 25k category - close enough, I recon.
AND, if anyone else posted but DID NOT "vote" in one of the categories, feel free to do so. It'll embellish the visual aspect of the poll.
Originally my intent was to establish a MEAN and a STANDARD DEVIATION, and even a MEAN TIME (MILES) BETWEEN FAILURES (aka MTBF) - and maybe still can, if there's more data.
Well, this is interesting! It's still early; we'll let it run a while longer until we get more data to develop some kind of statistical analysis going here.
Thanks to all that have responded so far with their experiences!
Old 07-17-2017   #26
Vette73
How do you think I felt? After Pete ported my inj housings and plenum I go to start the car, nothing.....Had to take everything off again and change the starter..Mierda !!!!! Car had 43K...
Vette73 is offline   Reply With Quote
