Old 06-06-2017   #21
Default Re: Secondaries issue...
Originally Posted by jss06c6 View Post
Interesting! Just took mine out and the LT-5 pulled like a freight train to 7,000, but if you are having issues with the intake tube between the filter and the throttle body, I'm going to see if I have any flex as well. Is it possible that it's a combination of air filter restriction and the flex duct age causing collapse? Mine only has 40k miles, but it's almost the same age ('91).
PS: Dominic, #473 is running like it's pants are on fire! I'm VERY happy with my tune! Thanks for the help..
Steve
Sent from my QTAIR7 using ZR-1 Net Registry mobile app
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-06-2017   #22
jss06c6
No collapse on mine and no supports installed.. I'll monitor..
Old 06-06-2017   #23
Ccmano
Ccmano's Avatar
That doesn't mean it isn't collapsing under load. That was exactly the problem, they looked fine but when the pressure dropped under strong acceleration they folded. I would do a test drive without it in place and see if u can tell the difference. In any case I would add the Haibeck hoops as cheap insurance.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 06-06-2017   #24
jss06c6
Will do!!
Old 06-06-2017   #25
S.hafsmo
S.hafsmo's Avatar
Darn.. Just ordered from Haibeck a couple days ago. Should've gotten the hoops.
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 06-06-2017   #26
ssrszz4
Mine seems nice and stiff but I guess one would have. To be in there with the engine well it's speeding down the road with a flashlight to really know.
ssrszz4 is offline   Reply With Quote
Old 06-06-2017   #27
jss06c6
Other way is on the dyno... But still worth the coin to prop it open..
Old 06-06-2017   #28
FWIW, I simply cut out a piece of aluminum flashing from Ace HW, lined the inside of the accordion tube, pop-riveted it and cut off the excess - about a 15 minute job. Works great, last ten years!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-06-2017   #29
ssrszz4
Are there any problems with the silicone sleeves?
Old 06-06-2017   #30
RussMcB
I'm happy with the one I got from Jerry's. My not-very-modified LT-5 made good dyno numbers, feels strong.
Of course, it probably would with Marc's hoops, too.
If Paul's mod uses flush rivets, it might be good for another extra .2 HP. :-)
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015)
MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3
[IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG]
