Old 05-25-2017   #21
WVZR-1
Default Re: Itty Bitty Bulb needed
I thought I had a LH switch panel with switches and I stumbled upon it today.
The window switch takes a pair of what is a T3 base with a height that differs from the links that I posted but a very clever person could use miniature bulbs with a wire terminal and salvage the base.
The mirror appears to be a T4 base and a very clever person could use a bulb with wire terminal to do a repair.
A T3 LED of some color would likely work but I doubt a color match possible and then to how to determine the brightness. I don't use and have no interest in LED for anything automotive that ain't OE.
Old 05-25-2017   #22
Originally Posted by BlackZR1 View Post
I just bought this part from GM PARTSGIANT. The bulb was $14 +shipping. I have no idea what I bought if the bulb isn't separate from the switch.
Old 05-27-2017   #23
I just got the bulb and I believe it's the bulb the OP is looking for,when Photobucket wants to cooperate I'll post a picture
Old 05-28-2017   #24
WVZR-1
OP - Where did you disappear to?
You've got a non-working so you can disassemble risking no loss at all. The amber filter is flexible and I've found some of my older work and believe there are very inexpensive solutions. I'm not un-wiring mine!
http://www.jkllamps.com/pdfs/CNW1_MULTI_LISTING.pdf
I'd shop either a T1 or T1 1/4 wire terminal and try a re-wire and the old amber filter. If a T1 1/4 would work I believe that Bulb Town has a filter also. No filter for the T1.
Old 05-31-2017   #25
Young1
Young1's Avatar
Cool Re: Itty Bitty Bulb needed
I am the op and just returned from mountain trip with Z. I cleaned her up and will get to the itty bitty bulb measuring this Saturday. Along with getting to some codes. She was rebellious three times
Old 06-03-2017   #26
Young1
Young1's Avatar
Me the OP just ordered T3 Neowedge bulbs on EBay. A four pack of what appears incadesense bulbs for five bucks. I can reuse the little condom like orange filter. I will report back when they arrive in a week.
Old 06-10-2017   #27
Young1
Young1's Avatar
"BlackZR1" posted correct information for "just bulb".
This is the bulb only!
OP - I've never attempted to match the bulb/socket and I've only ever seen it referenced to a Stanley #
If you've the bulb/socket removed presently I'd try to compare dimensions to a T3, T4. Dimensions are in the link.
http://www.autolumination.com/74.htm
Easier to read dimensions
https://www.ebay.com/p/?iid=382069402972&&&chn=ps
Many years ago I did several switch back-lighting projects for other than Corvette projects that used some Pontiac/Olds/Buick lighting. I believe I actually sourced most of the project using MOPAR.
This is from a later C4 FSM - Bulb charts are in the 8B & 8C sections of the FSM. The Stanley reference information is there also.
Attachment 6195
OP. It is indeed a T3 NeoWedge bulb. I purchased from a generic vendor on EBAY. Four bulbs for 5 dollars.
Steve Young
Second Owner
SOLD
SOLD
Old 06-10-2017   #28
Thanks for closing out the post. GC
