02-24-2017 | #21 | |
Re: Rear View Camera Install
Dave, This blue connector is clearly a 10 cavity connector. I think I can get to this one to repin. Once I unlatch it, the IP side should move freely. I have some pins, not sure which one this is yet.
02-24-2017 | #22 | |
https://www.waytekwire.com/manf/45/D...FYWEswodIDUCJQ If there's a GM dealer close see the shop foreman if the parts guy can't help you. TRAY 2 - DELPHI TERMINAL SHOP & there's maybe another in TRAY 5 Last edited by WVZR-1; 02-24-2017 at 01:22 PM. |
02-24-2017 | #23 | |
02-25-2017 | #24 |
I may not understand what is going on here. This camera might be Bluetooth. If not, when I did my backup camera I ran a wire with the camera cable to the radio. I connected to the backup lights for my input. Since I was already running 1 cable might as well as 1 more wire.
Chris
91 ZR-1 Red on Red #922 |
02-27-2017 | #25 | |
Which backup camera are you using? Will you share the camera's installation when you are finished? Thanks
1990 ZR-1 #2180 Red/Black Many of the usual mods for 460HP, tuned by Marc Haibeck ZR-1 Net Registry Member #1548 |
04-10-2017 | #26 |
Ok all. Finished the install of the rearview camera yesterday. Power and ground taken off backup lamps. Also attaches pic of the "elusive" reverse signal. Repinned it to take signal for appradio4. Works! I have run the camera cable down the left side of the car under sill plate and across the drivers side to the appradio4.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 03-08-2024 at 03:10 PM. |
04-10-2017 | #27 |
I'm using an Audiovox camera.
04-11-2017 | #28 |
Hi Dom--Do you have to cut a hole in your license plate for that? --Bob
04-11-2017 | #29 | |
No. The camera sits flush w the face of the rear fascia, is pretty small and is pretty much out of sight. I'll install the License plate and post pics. Pretty neat. The Pioneer will add guidelines to the image, altho the image is reversed.
04-11-2017 | #30 |
Here's what it looks like w the plate on.
