Originally Posted by WARP TEN
When I had my '93 (Jim's QB93) and took off the license plate bracket I could see my tank sticker. I removed and saved it in a picture frame. It turned out to be easy to remove, as I recall just using my fingers although I might have used a paint scraper. I approached it carefully and it turned out to be attached with only a couple of spots of some adhesive, which gave away fairly easily. You might try sometime to see if it can be removed easily. If not, leave it in place and as suggested by Charlie, order a copy from the Museum. --Bob
I think I'll just have Charlie pick up a copy. Mine was tucked in a bit and I didn't want to risk ripping it.
Thanks.
