Old 01-26-2017   #21
Default Re: 2nd winter project done Street Shop and rear Wilwoods
Non marring fastener attached to banski trailing arms no other to keep this cable in position and towards the right direction. I believe Dom did the same thing to his dog bones
Old 01-28-2017   #22
Clarification....I've been repeating the word "Teflon" washers as repeatedly stated over at Corvette Forum. These are not teflon but stamped metal with a nitrle coating. I have no idea why somebody would mistake that for teflon unless they had no idea what the coating was or is. GC
Old 01-28-2017   #23
Phil do you need anymore pics of the underside?
Old 01-28-2017   #24
cool!! glad you finally got them installed
Thanks -=JEFF=- you know how long I have been planning this one....and saving for this one
Old 01-28-2017   #25
Jagdpanzer
Jagdpanzer's Avatar
Thank you for posting the photos GC.
Still not clear to me how the new cables mate up to the existing E brake cable.
Do the new cables come with brake kit?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-28-2017   #26
phil,
No, u need to buy universal cables and then cut to length and make them up. U get them from Lokar. Perhaps Darryl can measure the length for u.
BTW, I used electrical conduit holders on the dog bones. And some split rubber hose between them and the dog bones as extra grip.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 01-28-2017   #27
Here is a picture of the GM stamped metal washers that you need to stack as recommended by Dom. Without these washers you won't get clearance you need for the unit when you tighten everything up
Old 01-28-2017   #28
Here's is the part number of the rear C5 Wilwood kit I used that fit behind my 17 inch wheels.
Old 01-28-2017   #29
phil,
Dom is correct I used the Lokar cable. I bought my streetshop setup used over at Corvette Forum and the cables where already made up. Here is a link for you Phil
https://www.amazon.com/Lokar-EC-80FU...ng+brake+cable
Old 01-28-2017   #30
Jagdpanzer
Jagdpanzer's Avatar
Did the Lokar cables replace all of the original cables? Did you also have to replace the E brake hand lever?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
