#21 | |
![]() ![]() Join Date: May 2010
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#22 | |
#23 |
![]() Join Date: Aug 2006
#24 | |
I believe I see a REMAN tag there also and if done while in WARRANTY or even exchanged while the transmissions were still exchanged by GM it would have been replaced with "correct spec" trans. I'm guessing yours won't have a correct VIN derivative and it might be interesting to see if the VIN derivative was actually removed or replaced by the REMAN facility. It might be interesting to compare the information on the tag with an OE tag. The parts list, the trans number and customer reference information might be of interest. Post that next time you're "under there"!! *** On your tag there's maybe a reference date to the rebuild of the trans. It could be Julian or maybe some other format but I do believe it might be able to be extrapolated from the tag. Looking at Rich's TRANSMISSION # it seems it's maybe actually just a date code. Is his 03/10 March 10th - 93 or maybe 0310 is NOV 06 - 93? Build date or date from Certification Label might be a clue. Last edited by WVZR-1; 12-27-2016 at 11:24 AM. |
#25 | |
![]() Join Date: Feb 2009
Rich
#26 | |
#27 |
#28 |
YOUR TAG blew my thoughts as to the relevance/relationship of the TRANSMISSION # being related maybe to a DATE CODE - LOL. That's good information for me though as I looked at a couple NOS transmissions I have(after posting) and I couldn't relate mine to a DATE CODE either. Thanks for that post of your tag information again. I had overlooked Jerry mentioning the TRANSMISSION # of his. I doubt that since the transmissions were an "import" that the sequencing of the TRANSMISSION # is relevant to production # (VIN) of the car.
My NOS BLUE TAG LT1/LT4 (089) is #'d 051708 and my NOS LT5 (087) is still sealed in the GM carton. I haven't checked it. Last edited by WVZR-1; 12-27-2016 at 01:05 PM. |
#29 |
This transmission was on the car when I bought it in 2000. I believe this must have been replaced under the warranty. I'll be replacing dual mass flywheel along with clutch, pressure plate, TO bearings as needed in near future. When I do, will take a better picture and post it.
Any "yes" - it has later output shaft. Hope all is well, David H! |
#30 | |
