12-11-2016 | #21 |
Re: Winter storage
12-11-2016 | #22 |
Re: Winter storage
12-12-2016 | #23 |
Re: Winter storage
1991 ZR-1 #520 Arctic White/Gray |
12-12-2016 | #24 |
Re: Winter storage
Better yet are those Sport seats on the wagon?
12-12-2016 | #25 |
Re: Winter storage
12-12-2016 | #26 |
Re: Winter storage
Not having my own garage, I have to keep my Beast in a storage unit. It gets pretty cold here in Southern Illinois, and I have never had an issue with any of my cars. Granted this is the 1st time I have stored a car. Last year all I did was fill the tank up, go every weekend and start her, and take it for a drive. If there was salt on the roads, I would just drive it around the storage facility...... I've always heard that is not good to let a car warm up by just letting it sit and idle.
12-13-2016 | #27 |
Re: Winter storage
FWIW ... I've stopped using a fuel stabilizer. I used to put it in my cars and small engines (generator, lawn mower), but I always had a hard time starting them in the Spring. I began using Seafoam and haven't had any issues starting in the Spring.
Although I store my Z with a full tank, I've heard people comment that GM recommends less than a half tank. It has something to do with the sending unit. IDK I start my Z up once a month in the winter and get it to operating temperature. Obviously YMMV
1990 ZR-1 #2180 Red/Black Many of the usual mods for 460HP, tuned by Marc Haibeck ZR-1 Net Registry Member #1548 |
12-14-2016 | #28 |
Re: Winter storage
Sta-bil 360 and Marvels Mystery oil. I fill the tank with gas use the correct amount of Sta-bil and Marvels drive the car one last time for the season. Usually a small 20 or 30 minute ride. I fill the tank, detail the car and take it to storage. Once she goes into storage I don't move or start her until she comes home for the next season.
For longer periods of storage I make sure to change the oil and gas every other year. Coolant every 5 years. All of my Vehicles are on battery tenders 99% of the time so I have never had an issue with a battery.
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
12-14-2016 | #29 | |
Re: Winter storage
12-14-2016 | #30 |
Re: Winter storage
You guys make it so complicated with all the additives
Here is Simple.............simple in that no mess and no fuss with the ZR-1s for 4 months 1. Install the Battery Disconnect Switch and Disconnect the Battery. 2. Fill the gas tank. 3. Make sure antifreeze is good for at least -15 deg F (3-1/2 balls floating). 4. Park the ZR-1s on floor mats to prevent condensation on a bare unheated concrete floor. 5. Use about 5 sheets of bounce poked into the Plenum Runners. 6. Use a Car Cover to keep the car clean which adds to the heating effect. 7. Do NOT start the car during the winter storage. 8. Move to California for 4 months and Drive the CA ZR-1s The Battery Disconnect Switch and Having an Operational Secondary Full Power Switch Explanation of Condensation on ZR-1 Undercarriage on a Cold Concrete Floor The condensation under a ZR-1 has less to do with the lack of a vapor barrier and more to do with a very cold concrete floor that remains cool for a long time after the ambient temperatures have risen. The warmer air carries more moisture under the car where that air is rapidly cooled and moisture condenses on any surface available and in this case the undercarriage of the ZR-1. The MATS prevent that cold floor from cooling the warmer air under the ZR-1 and the condensation is prevented. Any very cold unheated concrete floor will exhibit the same conditions. The higher the undercarriage is from the floor seems to reduce the condensation as shown in the photo below whereas a Toyota Tacoma does not suffer the same situation as it has about twice the undercarriage clearance as do the ZR-1s. A moisture barrier will not stop a concrete floor from sweating. It will stop the mitigation of ground water through a slab if done correctly. Sweating is caused by a combination of concrete temperature and weather conditions. If the concrete is cold enough and the temperature and humidity high enough the slab will sweat, regardless of a barrier. See Winter Storage
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-15-2016 at 06:27 PM. |
