Old 11-14-2016   #21
alexco
Default Re: ZR1 quites running after short distance
marc, I checked and there are 6 bolts plus the center stud so it is not the manifold to the heads, which means it is most likely the manifold itself, cracked somewhere. I hear that is a problem with these manifolds but I can see the crack, where do they usually crack? thanks.
alexco is offline   Reply With Quote
