Old 10-31-2016   #21
Pete
Pete's Avatar
Default Re: Coil Problem
Swap the coils around and see if the problem persists. to rule out bad coil / Wire
Ditto.
Also back in the hey day they had a problem with the lower spades on the coils being too loose.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-31-2016   #22
Locobob
Originally Posted by Pete View Post
Ditto.
Pete
I've already replaced all the coils and the problem came back so pretty sure its not a coil at this point. I did notice when I plugged the coils onto the spades they really didn't seem to have much resistance, they just dropped on kinda dropped on and felt loose. What have people done to get a better connection from the coils to the coil spades?
Robert
Old 10-31-2016   #23
Locobob
Ditto.
Pete
What symptoms were people seeing with this problem? Failure of the coil to fire at full strength or just not at all?
Robert
Old 10-31-2016   #24
Pete
Pete's Avatar
It was like they had a miss.
Like a bad coil.
See if u can stick something small and sharp like a dental tool to tighten up the spade in the coil.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-31-2016   #25
Locobob
You know now that I think about it I seem to recall someone adding material to the coil spades for a tighter fit.... does that sound familiar?
Robert
Old 10-31-2016   #26
You would think however that would affect the coil itself. Here we have an issue w one of the towers.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 11-01-2016   #27
Locobob
Yes I would think that would be true, and it may be that I am dealing with more than one issue here and am getting too focused on the one coil tower.
Robert
Old 11-02-2016   #28
Locobob
So I decided to do some testing on the fuel side:
Doing the FSM chart A7 fuel pressure test with FP2 removed resulted in 45psi - about 4psi below the minimum okay range for the test.
I also used the fuel pump test circuit with a multimeter, I saw just over 4 amps draw on each pump and about 8.5 amps with both pumps running.
Activating each pump through the fuel pump test circuit and checking fuel pressure I got the following:
FP1 fuse removed resulted in 51psi
FP2 fuse removed resulted in 42psi
Shouldn't both pumps be the same PSI when activated individually through the fuel pump test circuit?
Robert
Old 11-02-2016   #29
Like a bad coil.
Pete
Unless the DIS is failing. But I haven't seen that happen yet
Old 11-02-2016   #30
Locobob
Just did some more testing:
MAP checked out okay
Fuel pressure at idle is 42psi
Right Block Learn at 128
Left Block Learn at 144 - indicating fuel is being added
Robert
