Old 10-26-2016   #21
t5irocz
Default Re: A few parts-Chrome Alt, GM Exhaust Manifold Gaskets, TPMS, 970C Filters, and more
I am having a guy look this alternator over tomorrow with some test equipment but when I took it apart everything looked brand new inside including the Brushes, Bearings and Voltage Regulator (At first I thought the brushes were worn but actually not worn at all). This Alternator will be my spare for 1990 #72 and will eventually be installed on #72 which has relatively low mileage
Cool!! Hmmm... when I replaced it, I did the battery (which wasn't too old) and the alternator at the same time... for all I know, it could be just fine... I hope it is! Looks great with that pulley!!
ERIK
-92 Z28 1LE, L98, 6K MILES, 25TH ANNIVERSARY Z03, 1 OF 4
-91 Z28 1LE, L98, 6K MILES, RADIO DELETE
-87 IROC-Z, L98, 11K MILES, SURVIVOR
-90 CORVETTE COUPE, L98, 6-SPEED SHOWCAR
-15 SILVERADO & 16 TAHOE DAILY DRIVERS
FORMER 90 CALLAWAY ZR1/CR1 OWNER #2276
:flag:
t5irocz is offline   Reply With Quote
Old 10-27-2016   #22
t5irocz
Hi Jerry, I just went to write you back but your PM inbox is full. You can email me at ayrikzr1vet@aol.com. Thanks! Erik
ERIK
:flag:
Old 10-27-2016   #23
Rectifier was shorted out and you could tell by looking at rear of Alternator where you can see the Rectifier. Ebay.....is sending me a new rectifier
Apparently someone dropped a screw or otherwise shorted out the rectifier from the rear
It be a 130 amp Alternator which is very nice
Old 10-27-2016   #24
I thought it would have least been a 200amp and I thought seriously about buying it
Old 10-27-2016   #25
Talking and Doing are two different things
It is the prettiest Alternator Inside and Out I have ever seen
I was only thinking ..... talking requires higher level of thought. To be honest with the Corsa and Street Shop rear upgrade it was just another project that I could not afford to take on to be honest
Old 10-27-2016   #26
This will be a great Alternator to photograph it all apart (like it is now) and assembly in a week or so with identification of all the parts
Front Housing, Armature, Pulley, Bearings, Stator, Terminals, Commutator, Voltage Regulator, Brushes, Rectifier, Rear Housing.
All the Parts to Alternators are available on Ebay.
And ....and.....MCH-208 Pulley installed.
I will start a new thread just for the fun of it.....will call it.....Alternator Restoration
Back to t5irocz as we kind of interrupted his parts for sale (he is adding more this weekend) so I guess we are keeping the thread alive.
I still have the following:
-tire pressure monitors
-NOS black oil filters
-Hood Strut
-92-93 information center
-Sway bars front and rear
-Air Filter Cover, OEM used
I do have a couple other parts that I found tonight. I'll try to take some more pics tomorrow:
-"Corvette" embossed clear sill covers - $20
-New GM air filter cover - $35 - same dimensions as the original one to my car but also has a factory dust shield
-Brand new NOS GM windshield weatherstripping (the one that always gets tattered on C4s). New in the box. I bought this 15+ years ago and never used it. I will look up my slips to figure out when I spent on it, that will be the price.
Thank you all again for the interest in the parts and the purchases! Anything paid for today will ship out tomorrow.
t5irocz
.......I can delete all my Alternator Posts as you like....I just got excited a bit over its great condition
Old 10-28-2016   #27
t5irocz
t5irocz
Haha i'm just super happy that you like it!! Thank you again so much for buying it! Glad you were able to figure out the issue quickly!
The NOS oil filters are now all sold! Most of what I originally posted is now gone (Thank you all!!!)
I have more that I found in my basement this week that I will post up for sale soon, stay tuned! This has been very helpful in getting my basement organized for the winter and I appreciate it, Thanks again everyone!
ERIK
:flag:
Old 10-28-2016   #28
How do you know this? I have one I need to finish building.. it has a new rotor and Stator, I need the rest of the pieces..
Suggestions of a place to get the Rectifier and regulator?
Old 10-28-2016   #29
On the Ebay rectifier it suggests it is 130 amps. I searched until I found an identical appearing rectifier and will let you know if it works
The Stator Core has three wires that connect to the Rectifier. I guess the Stator Core determines Amps (also depending on Rotor/Rotor speed) but it is more complex than that and when I get this Alternator back together I will just have it bench tested
All Parts are on Ebay if you know which Alternator you have. Brushes, Rectifiers, Regulators. Prolly Staters, and bearings as well.
On this Chrome Alternator it was suggested it is Powerhouse Alternator and my local expert suggested it could be almost anything with some Powerhouse Components. I know the Brushes which are new on this Alternator I did find identical on Ebay under Powerhouse.
On this Alternator we found the Rectifier was burnt to a crisp on two diodes as someone dropped a screw or something on rear of alternator. My guy suggested to check the Stator Wiring for burning also which I did and which wiring was perfect so Rectifier was apparently just grounded itself. The Bearings, Brushes, Stator, commutator, and Voltage Regulator all appeared to be new.
Oh....and apparently O'Reilly's will test an alternator if you bring it in (off the car).
Old 10-28-2016   #30
Yep they will hand you a print out of what is good/bad during the test cycle
