#21 |
#22 |
Yes dynomite...now i have an other light on...abs service!!!
I dont remember the number code but its an issue on rear wheels. I already clean the abs sensors reset code and after few kilometers the light come on :-( |
#23 |
If i well remember the codes are 26 and 36...i hope i m not the only one!!!!!
#24 |
Hi Max,
You may get more response if you bring up an old post with a similar problem to what ever you are facing, or a new post on that issue. I don't know the code #s but have had ABS faults due to loose wheel hubs, which can happen when you run hard on modern performance tires. Probably worth checking by jacking the car up and shaking each wheel (left/right and up/down), any more than just a little play (both directions) indicates it's time to replace. It usually takes a lot of play before ABS has trouble though. Hope that helps, - Jeff |
