Old 06-27-2016   #21
Billy Mild
Default Re: Back from the dyno and disappointed
Originally Posted by Kevin View Post
if you have a factory duct that's not reinforced we found your problem
Is 330 RWHP and high heat outside the straw that breaks the camels back? The LT5 just has that much vacuum?
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 06-27-2016   #22
Kevin
Kevin's Avatar
squeeze the factory duct when it's hot and see how easy it is to collapse, it's terrible. I forgot how bad it is since I've had an upgraded one on mine for nearly the entire time i've owned it.
Old 06-28-2016   #23
cvette98pacecar
Next time you go to the dyno take the accordion off, Let your beast breath.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 06-28-2016   #24
rush91
Wow I never even thought of that....mine is original. Where did you get your aftermarket one?
rush91 is offline   Reply With Quote
Old 06-28-2016   #25
Kevin
Kevin's Avatar
I bought the last one that mark coplan had years ago at BG. Mark Haibeck, sells a solution that I would look at. Both keep the factory appearance and provide a more robust duct to keep it from collapsing. Coplan used a piece of aluminum inside the duct to keep it collapsing. Haibeck uses hoops. http://www.zr1specialist.com/HAT%20W...ucts/hoops.htm that's a link for Habieck's one. Back when coffee cans were metal some people used those, cut up, to fit.
Old 06-28-2016   #26
Billy Mild
http://www.jerrysgaskets.com/duct-si...lue-90-95-12a/
Jerry's makes a new one too.
Looking for a ZR-1
Old 06-28-2016   #27
Yep! Been so long ago. I fashioned a liner out of sheet aluminum (smoooooth!) and pop-rivets. That solved my collapsing accordion - was choking out at 5500 rpm. No more!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-28-2016   #28
Kevin
Kevin's Avatar
Didn't realized jerry made one. I'll add that to the mental list
Old 06-28-2016   #29
rush91
I didn't even think of that....Marc has done maintenance on my car a few times. I'll check tonight, I may already have some in there.
Old 06-28-2016   #30
rush91
Wow, that Jerry's one looks very nice! Hmmmmmm choices
