Old 06-13-2016   #21
tpepmeie
Default Re: Injector Rail
Todd,
For purposes of comparison, aren't the Bosch injectors rated at 43.5?
It depends on who's quoting them. Most aftermarket resellers will use 43.5, because it is more standard. However, if you use Bosch-made Ford Motorsports injectors, they are typically rated at 39.15 psi. For example, the red Bosch 30-lbers I had in the 427 were Ford Motorsports injectors rated at 30lbs @ 39.15 psi. Ford provides calibration data which had the characterizations at all different pressures (they flow ~35 lbs/hr at our rail pressure.) The conversion from Ford characterization to GM tables is quite involved, but can be done.
Using a 50.8psi fuel pressure brings flow for the RCs to 21.5.
Not sure that the calibration value is at a 50.8psi. You might be able to shed more light on that.
I wouldn't speculate on what or why the GM calibration uses that 22.7 flow rate--I've always wondered that myself. I'm sure there is a reason. However, to accurately meter the fuel delivery, that variable needs to reflect the operating conditions of the injector. There is no other calculation in the program which converts that data value to the actual rail pressure. The regulator is designed to deliver a constant 3.5 bar (50.8 psi) pressure difference between the manifold and the injector feed. It's the flow rate under those conditions which dictate how much mass of fuel is delivered for a given pulse width.
Years ago, I had some lightly used stock injectors tested. They flowed 20.1 lbs/hr @ 43.5psi, which is 21.7 lbs/hr @ 50.8psi. Still short of the factory calibration value (22.78). It is possible that the flow v. pressure is not perfectly linear for the multecs, but who knows.
Todd
____________________________________
*** our email address has changed!
info@pepmeierengines.com
pepmeierengines.com
Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384
Pepmeier Engine Development
Old 06-13-2016   #22
Todd,
Thanks great info. Yeah, 43.5 seems to be the standard most vendors use, although the Accels were usually shown at 19# @ 39psi. They were mostly used for Mustangs I believe.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-14-2016   #23
tpepmeie
One last point. If anybody uses the ford motorsports injectors and wants the injector characterization data converted to our GM calibration, that is a service I can provide. I can recommend a suitable model if you aren't sure.
Todd
pepmeierengines.com
Old 06-14-2016   #24
Todd,
And just to underline the point of using that data, one "tuner" both of us respect won't tune a car without the proper bias curve.
Old 06-15-2016   #25
tpepmeie
Banish?
Todd
pepmeierengines.com
