Old 02-26-2016   #21
Default Re: Misfire
It's possible the O2s "drop out", meaning the signal goes to 0, but that would suggest a lean condition to the ECM. I saw that happening on a number of my logs until I finally changed out the Bosch 02s for AC Delco. Then the signal was solid as a rock.
The symptoms that this is happening at idle and below 3000rpm suggests it's happening at higher vacuum/lower MAP. So question is whether there's a vacuum leak causing a lean condition and so a stumble?
If u have Bosch 02s, I'd swap them out for the hell of it.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-26-2016   #22
ZRXMAX
ZRXMAX's Avatar
Default Re: Misfire
Solid recommendations ! Don't know why I didn't think about these a while ago. Bad 02 sensors can really cause weird things to happen. Will try it tomorrow. Thanks
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black
ZRXMAX is offline   Reply With Quote
Old 03-10-2016   #23
ZRXMAX
ZRXMAX's Avatar
Default Re: Misfire
I found the problem... cam cover bolts adjacent to the #1 spark plug were getting loose. Lesson learned!
Old 03-10-2016   #24
Default Re: Misfire
Which Cam Cover Bolts?
How Loose?
Exactly how does a loose or a couple loose cam cover bolts cause a misfire?
Was Number 1 Spark Plug Port full of oil (were the Cam Cover Bolts THAT LOOSE)?
That Loose as to cause the Cam Cover "O" Ring to fail on Number 1?
Old 03-10-2016   #25
Default Re: Misfire
You're about 3 weeks early. April Fools day isn't for another 3 weeks yet, but you sure got me on that one.
Old 03-10-2016   #26
Default Re: Misfire
I am confused
Two issues reported recently (This Misfire issue and a Pilot Bearing or Throwout Bearing failure at 20K miles) and my issue with a cracked impeller on a NEW Water Pump ....I am thinking ANYTHING IS POSSIBLE
The Cracked Water Pump Impeller (NEW WATER PUMP) issue I caught right away but did take a bit of diagnosis to eliminate an Air Locked Water Pump as I had just drained Coolant.
Damn.....I am not even looking at this Forum on April Fools Day or for a week after
Old 03-12-2016   #27
ZRXMAX
ZRXMAX's Avatar
Default Re: Misfire
How Loose?
When I was putting the plenum back on for the third time and holding a 40 torx in my hand I looked at those bolts and thought... I wonder if they are loose?
Indeed they were ! I estimate they might have had 10 lbs of torque on them as they sat. Keep in mind their was no oil or any leakage of anything to be seen inside plug hole # 1.
So, I looked up the torque number and applied it.
Keep in mind I had reported early on that the #1 boot kept coming out. When I would re install it the connector would emit that little click that indicated it had slipped into place at the top of the plug.
To get it off required the same amount of effort as any other plug. So, I have to assume air pressure was building up and blowing it off.
I will see what I can come up with for April Fools !
Old 03-13-2016   #28
Default Re: Misfire
You have more patients than I do. After the first plenum pull,if the problem is still there I'm throwing new parts at it.🤑
Old 03-13-2016   #29
ZRXMAX
ZRXMAX's Avatar
Default Re: Misfire
Originally Posted by Z51JEFF View Post
You have more patients than I do. After the first plenum pull,if the problem is still there I'm throwing new parts at it.��
I did throw new parts at it... actually, I was recycling parts that were stilll good but were removed as preventative maintenance. Coil packs, ECM, chip
inside ECM, map sensor, plug wires, spark plugs... also checking fuel pressure several times, and, new O2 sensors were installed. We were down to 3 items. The module under the plenum, crank sensor, or cam sensor.
We also did a data log on a short 4 minute run and everything appeared to run in the normal range... so... the head knocking was getting painful!
Old 03-13-2016   #30
Default Re: Misfire
The cam position sensor will give a code,can't remember what it is. The full power will be cut,check engine light will come one and the car will run like its starved for fuel,at least that's what mine did but it didn't have a miss.
