01-15-2016 | #21 |
Re: Corey does his magic
Graham,
Any thoughts on the Mercury Marine heads mated to an LSx block?
01-15-2016 | #22 |
01-15-2016 | #23 |
Would make for an interesting alternative to the LT-5.
01-15-2016 | #24 |
Just a few comments on information stated earlier in this thread:
The LT5 was a premium fuel recommended application, so the production released ignition timing was about 5 degrees from borderline detonation. In test 1 form, as installed in vehicle with vehicle intake, exhaust and calibration the 1993 engine made 405 hp SAE corrected. In test 20 form, max potential, with open inlet, headers and LBT/MBT it made 445 hp. So there is easy power to be made from ignition timing and fuel on a stock system, add headers and more timing can be added, reducing back pressure tends to make the knock limit higher. Graham. |
01-15-2016 | #25 |
Graham,
When dyno tuning my motor, I have found that knock appears to occur at ~4500-5500rpm range. However, beyond that the LT-5 appears to be knock tolerant. I've had WOT timing up around 34-35d with no indication of knock occurring at that level. Just a loss of power. AFR is ~ 12.8:1. How does that square w your experience and expectations?
01-15-2016 | #26 |
On 93 octane fuel I would agree with the above.
Graham. |
01-15-2016 | #27 |
Yes it's 93 Octane 10% Ethanol. Which brings up the question of doing E85 on an LT-5.ยข
01-15-2016 | #28 | |
01-17-2016 | #29 |
The tires do appear to be slipperier, than they were before.
