Old 03-10-2016   #21
Billy Mild
Default Re: Nitrous
How did the old NOS kit work? I assume they had some failsafes in place.
Old 03-10-2016   #22
Hog
Default Re: Nitrous
This $785 kit from ZEX is for the LT5 powered ZR-1 Vettes. Its a dry 75-1254 hp kit.
http://www.summitracing.com/int/part...k-lt5-corvette
Heck N.O.S. even used to have a specific kit for the old Crossfire dual TBI engines. Dom S is mentioned as having a Crossfire Vette that ran a 13.3 in the 1/4 running Extrudehoned runners in an old 2006 post.
Old 03-10-2016   #23
Billy Mild
Default Re: Nitrous
Now this just got interesting.
Old 03-10-2016   #24
Fully Vetted
Fully Vetted's Avatar
Default Re: Nitrous
Originally Posted by edram454 View Post
I agree! I was just saying for those who have stock cars and those of us who have modified cars... the gains are fantastic!! I would be over 500 horse too, just imagine the look on the faces of those guys with these new supercharged cars when they see the power the lt5 350 cube engine can deliver. 100 horse is mild,, 150 is mild too... I said 100 to be super safe and never have any issues hitting the nitrous all night long! The motor is stout enough to take a harder shot of nitrous and still be o.k.
No doubt. Gas has always been the most economical way to add power. And lots of it. For those of us that are modded even a quick little 75 shot just to be extra safe would be a real blast.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 03-11-2016   #25
Karl
Karl's Avatar
Default Re: Nitrous
Nice.
Been thinking about nitrous oxide and methanol injection.
http://www.alcoholinjectionsystems.c...articles_id=56
The 75 - 125 hp with a small shot of methanol should work fine for a easy 11 second car.
Old 03-14-2016   #26
Default Re: Nitrous
Got a wet nitrous kit need:
*Window Switch
*Prom setup or way to retard timing
http://ampperformance.com/i-9570823-...ystem-kit.html
Old 03-19-2016   #27
Default Re: Nitrous
purchases an MSD window switch http://www.summitracing.com/parts/msd-8969/overview/
just need to address timing
Old 03-22-2016   #28
Billy Mild
Default Re: Nitrous
Can't you create 2 tunes with using the power key function? I would make it normal power would be Full timing, then when you click the key over to full power it would retard the timing.
Old 03-22-2016   #29
tpepmeie
Default Re: Nitrous
No, because I presume you'd want to still have access to full power operation when off the bottle.
What I'd recommend is wire the window switch into an open input on the ECM and apply a spark retard when active. Alternatively, you could have the PT Open spark tables active when the window switch is closed (versus when the secondary bit is set). This becomes a lot easier if you don't have secondary throttles.
Note: the later calibrations have exactly this feature, although the tables are zeroed. The EBTCM sends a binary signal to the ECM, which then retards timing by a specified table amount. That was the secondary form of traction control (spark retard), the first being mechanical throttle modulation.
Old 03-22-2016   #30
Billy Mild
Default Re: Nitrous
I meant have both settings be "full power" where they would always open the secondaries, but one of the two power settings had retarded timing.
