Old 06-05-2015   #21
Default Re: Anybody ever replace the clutch safety switch?
Originally Posted by RussMcB View Post
Before I'd dive in to R&R the starter, I'd try rigging up something (perhaps temporarily) to provide 12v straight from the battery to the starter (perhaps via relay). The purple wire is fairly accessible and not hard to splice into. If the car always starts that way, you'll know the starter is not the problem (which is good. They are pretty deep to get to, and hard to find or expensive if you decide to buy a new one).
Hope this helps.
If you are going to cut the purple wire for diagnostics....After hot wiring your Solenoid to see that it functions, check the voltage on the hot side of the purple wire from the clutch switch with key on (Start) and clutch depressed. If you have 12v......just get the Relay and be done with it
80 amp relay on Ebay
Bypassing the Clutch Switch is NOT the answer
Removing the Secondaries for a leaking Vacuum System is NOT the answer.
Blocking TB Coolant IS the answer. (These are all different questions)
