05-27-2015 | #21 | |
Re: Jumper to avoid being stranded with a failed Primary Fuel Pump
05-27-2015 | #22 |
Ok any others out there ?
05-27-2015 | #23 |
I'm in-- with additional cost to ship to Canada.
05-27-2015 | #24 |
I am in as well.
05-27-2015 | #25 |
05-27-2015 | #26 |
I'm in. Never needed one before, hope to never use the one. But...
91 ZR-1 Red on Red #922 |
05-28-2015 | #27 | |
What is the shortest jumper you can make? It would appear that the shortest jumper would be with two new connectors back to back with just enough room to cross wires green and gray (white).
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-28-2015 at 09:26 AM. |
05-28-2015 | #28 |
Count me in for 2.
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
05-28-2015 | #29 |
I would think you would want sufficient length between connectors to maybe pass the four wires through a "heat-shrink" tube when constructing and then shrinking to keep the bundle secure. Wouldn't need to be long but I believe needs to have some length to avoid struggling when connecting.
I'd think Jim has first-hand knowledge of a practical length and I'd certainly inquire/enlist his help before constructing. Cliff - did you check the "clocking" of the black and green/white on yours? |
05-28-2015 | #30 | |||
I am going with what Jim described as follows.......and I am assuming 90's and 91's are identical. Quote:
Purple I call Red, Gray I call White, Green/white I call Green. Quote:
Four Jumpers for Dynomite.......
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-28-2015 at 11:36 AM. |
