05-19-2015 | #21 |
Re: Brake Recommendations Please
Sam,
Would you explain further what you mean by the C6Z brake piston volume adjusted for C5-6 but not C4? I have the C6Z brakes, front and rears and using stock master/booster. In the 2 years of driving I have not sensed any inadequacy from them. I first had just the fronts, then upgraded the rears last year including the eBrake. I don't track the car although I have hauled it down from 225km/h+ a few times with no drama. Having enough brake is the least of my concerns. Yes they do look nice behind 18"+ wheels. One of the reasons I did it was due to limited tire availability for 17s.
05-19-2015 | #22 | |
what is the 6 piston setup going for?
90 Chevy ZR1 LPE #2315 'SOLD' 90 Chevy ZR1 LPE #2774 'SOLD' 91 Chevy ZR1 Callaway aerobody 91 Chevy ZR1 #1512 91 Chevy ZR1 #951 95 Chevy ZR1 #338 'SOLD' 91 BMW 850i 94 BMW 850csi 95 BMW 850csi 94 Lotus Esprit S4 07 Benz CLS550 06 BMW M5 "SOLD" |
05-19-2015 | #23 |
The C5 brakes are mounted on caliper slides and have a little bit more give and play resulting in a slightly less firm pedal. Although I have been in other C4's with J55's that weren't super great feeling- it does seem to vary from car to car.
You will have to spend more than a $1000 to do C5 brakes if you don't have the wheels already. I did mine only because I got a box of parts when I purchased the car. The rotors are cheaper (and thicker) plus you do get a lot more brake pad on the disc. My conclusion is not so much about the brakes, but the weak gain on the brake booster. Regular non ZR-1 C4's are especially weak feeling with only a single diaphragm booster. Last edited by mike100; 05-19-2015 at 10:52 PM. |
05-19-2015 | #24 |
of course don't forget to budget for a spare tire solution with big custom brakes.
05-20-2015 | #25 |
Thanks a lot guys. this has been very instructive.
Though I'm the type that generally looks for an opportunity to upgrade, I think I'll stick with the stock setup. Mostly for the impression that I get that the C5 upgrade will improve the car's ability to withstand repeated hard stops without fade, but would not give it that seriously shorter stopping power that I had wanted for the $$. Also, Although I have A-Molds mounted now, I want the ability to go back to my perfect set of those beautiful original saw blades if I choose. We're going with new stock type rotors, new brake lines and pads. Thanks again.
"It's about the car, not the people." 1991 ZR-1 White/Black #1236 (Owner since 1994). Stock engine with bolt-ons: Hurst shifter,"Forced Air" intake, Coplon duct, Bee Cool Radiator, Demon coils, Jeal prom, Watson headers, X pipe, 3" B&B's, Rippie flywheel, 4:10 gears, A molds, Toyo Proxes-R888's 12.06@117mph. 1.76 60ft. |
05-20-2015 | #26 | |
The C5/C6 stock caliper pistons work with a 2 x 40.5 mm diameter, those from the C4 with 2 x 38 mm. The volume difference is about 14%. When you install C5 brakes in a C4, the fluid volume ratio between the C4 main cylinder and the C5 calipers does not match. The consequence is the brake pedal become soft. With a Mov'it brake you have a hard pedal. We wanted to open for C4 drivers the possibility to have a high performance brake without additional costs for the necessity to go with expensive 18 inch rims and tires. For the 17 inch stock rims exist the following brake upgrades: Front: 322 x 32 mm with 4 pistons 342 x 32 mm with 4 pistons 342 x 32 mm with 6 pistons Rear: 299 x 28 mm with 4 pistons and overtaking the stock C4 caliper for parking brake 342 x 28 mm with 4 pistons and a seperate small parking brake caliper No spacers are required because the additional necessary offset is already in the 2 piece rotors implemented. It also exist a 370 x 32 mm 4 and 6 piston upgrade but this set require 18 inch rims. I don't want to say the C6 Z06 brake is bad but this system is just not calculated for the C4 and its about 400 lbs heavier car body. Running a C4 hard in the hills or a race track you will feel the difference between the Z06 and a Mov'it brake.
Sam DR.Z/LT5-Performance 1990 #1822 with 383 cui |
05-20-2015 | #27 |
Sam,
How does the difference in "swept area" play into this? You are looking at front/rear rotors that are 1" larger than the stock ZR-1 rotors. Again, I don't race the car, but my experience has been that the pressure needed to slow/stop the car is noticeably less than w the Brembos I had up front. I see that u have a 90 and it's my understanding that the master/booster for the 90 is smaller than what was used for subsequent years. Some have used Camaro master/booster for use w Wilwoods for example. In my 92, the master feels more than adequate in terms of pedal feel and travel in combination w the Z brakes. Just to clarify for others following this thread, my beginning objective was to use the Z06 wheels for the aesthetics and tire availability. Originally the car came w Brembo fronts under A molds. When I switched to Z06 wheels, the front tires protruded past the front fender noticeably. Part of the issue was the extra thickness of the Brembo rotor hat. Swapping in the Z06 calipers allowed use of the Z06 rotors, which are heavier, but they also reduced the offset putting the outer edge of the front tire almost virtually in line with the edge of the front fender. The 19s, on the other hand, made the 12" stock rotors and caliper look rather puny. I do use 18mm spacers on the rears for the proper wheel/fender alignment.
05-20-2015 | #28 |
Thanks Billy
[/B]QUOTE=Billy Mild;226004]http://www.amazon.com/Dupli-Color-BC.../dp/B000B6AF80 I used this, but got it from Advance Auto Parts. I wanted to use the paint brush route as I feel the coverage was better. I did about 3-4 coats. Brake fluid will still ruin the finish so be careful.[/QUOTE]
WAZOO MEMBER 1993 #124 Ruby 1994 #??? Red/Black 1995 #061 Black/Red 2012 ZR1 Preproduction |
05-20-2015 | #29 |
Bob, if anything you may want to consider finding C4 Grand Sport calipers, they are direct swap to yours but are a stronger caliper
05-20-2015 | #30 | |
Sam, you bring sound tech to the brake upgrade question but I have to take issue with this statement:
The PBR caliper is certainly not the best in the world but it is far from the worst. You will see some pad taper owing to the caliper flexing, but you have to work 'em pretty hard to get there. There are a lot of different configurations of C4 brakes, with varying pedal ratios, different master cylinder piston sizes, different caliper piston sizes etc. All of these things, along with rotor diameter, can be thought of as levers. More lever equals more work per input. My personal battle with the 91's brakes are due to the smaller pedal ratio, the small master cylinder piston size, and I believe the inability to bleed the ABS unit. Bear in mind my prior autocross car was a 99 Cobra with very similar calipers/rotors but a MUCH larger master cylinder piston. Long pedal travel is not a great answer in my use of the car, but I can see how it would be very beneficial at 150mph! Cheers, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
