04-26-2015 | #21 |
Re: Cheap "thrill" ho-boy.
Geez Paul, that'll wake you up!
04-26-2015 | #22 |
I agree, but when you have to remove the wheels and don't have a lift...
Jim Zorgias 1994 ZR-1 Admiral Blue/Black #245 1996 Callaway Supernatural 450 1990 Callaway Supernatural 490 / CR-1 #7 |
04-26-2015 | #23 |
Back when I was on Kim Baker's racing team, he got a lot of assistance from Bernie (forget his last name), owner/editor of "Keeping Track of Corvettes" magazine. We lost Bernie due to an accident in his garage when one of his cars fell on him. Very sad for the family and racing team. I think about that often when working under my cars.
The KwikLift (and Race Ramps, I assume), don't seem near as useful since I'm usually removing wheels and tires more often than not. The thought of a car on jack stands during an earthquake had not occurred to me, and I lived in California (but I was a dumb 16 YO and didn't put a lot of thought into much of anything. :-) The Ranger Quick Jack looks pretty cool, but after using a jack and stands for 40 years, I suppose I can keep doing that for a few more.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015) MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3 [IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG] |
04-26-2015 | #24 |
If all one is doing is removing tires or doing a brake replacement, then a simple hydraulic jack at the lift points behind front wheel and in front of rear wheel on the side you are working on is about the safest and quickest method. A Jack stand is a safety measure on the corner you are working on.
04-26-2015 | #25 |
One thing that might help is an adapter that mates the hydraulic floor jack "CUP" to the pinch weld on the frame. as it is right now, the "CUP" on the floor jack catches the foot well and/or the rocker panel, damaging either or both, sooner or later. OR, I suppose I could fabricate one too. As it is, to avoid damaging either the foot well or the rocker, I end up moving the jack pad (cup) toward the areas where the jack stands would be placed, interfering with the jack stands (the basic problem) placement. (I guess I'm on a roll: my "wish list" is fresh on my mind!)
04-26-2015 | #26 | |
Had one tire guy (when I was not looking) place jack under rocker one time....NOT GOOD. So have to know stuff to not destroy stuff 3 ton Pittsburgh Racing Aluminum Floor Jack
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-26-2015 at 04:29 PM. |
04-26-2015 | #27 | ||
04-26-2015 | #28 |
My jack stands have a "slit" cut into top. Its also "cupped". There are some sections of the frame rails and body that fit in the slot. In fact there are chain holds that were likely used in the build process for the body. These slide into the slot on the jack stand. That's what I use whenever I put car up.
I'd like to get one of those floor jack adapters that fits between the exhaust pipes and raises the car at the diff.
04-26-2015 | #29 |
I have the same Jack as Dynomite - works good.
04-26-2015 | #30 | |
http://www.corvettegadgetman.com/products3.html
