Old 04-24-2015   #21
Locobob
Default Re: ported plenum and injector housings..
There is enough extra fuel in the factory proms WOT program to support some breathing mods. You can generally get away with headers or porting but not both without adding fuel.
Robert
Old 04-24-2015   #22
Pete
Pete's Avatar
We need to clarify,there is some differences in porting.
The price does not tell the whole story.
There is two different ways to porting 35mm and 36mm
On the 35mm i use a 35mm gauge ball that will drop straight thru primary port (1990-1992 IH's).
On the 36mm porting i use a 36mm gauge ball that will drop straight thru (1990-1992 IH's)
35mm $650 this is very easy and less time consuming no fears
36mm more time consuming have to be very careful getting close to water and oil jackets most don't do 36mm $1000
$150 reprogram prom.
On my IH's i made the 36.5mm gauge ball drop thru this is very scary my IH's are like l98 intake runners
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-25-2015   #23
Just to clarify, Anyone who has had their intake ported by me knows the ports are larger than 35MM,typically the smallest part of my primary runners are 35.3-35.5MM+ around water jacket areas.
I leave some safety margins as with powdercoating you have to sandblast....going too thin and you start blowing through the runner walls.
I enjoy doing porting which is why I offer it at a reasonable price. Both Pete and Locobob do a great/awesome job with their porting. I started doing this as a low cost alternative for those that could not afford more expensive porting.
Old 04-25-2015   #24
Vette73
Yes.....Better to be safe than sorry....Will be in touch soon ..
John...
Vette73 is offline   Reply With Quote
Old 04-25-2015   #25
Jim Nolan
Locobob,
In my case I have to disagree with you on the fuel scheduling after porting. When you did my plenum and injector housings it ran a little better but felt lean. When Marc reprogrammed my chip it ran a lot better, actually much stronger. Maybe it was just my set up to begin with, factory. Whether you did mine 35mm or 36mm only you know.
Old 04-27-2015   #26
chris313scorpion
Pete,
How much more to do the disassembly also? ie drive my car to you, you disassemble, port and reassemble and I come get the car?
chris313scorpion is offline   Reply With Quote
