02-11-2015 | #21 | |
Re: Higher than normal Idle, and occasional stumble
02-11-2015 | #22 | |
I have found in addition to that check valve failing, that the usual vacuum leaks are caused by the rubber connectors getting hard and shrink with age on the ends of the hard plastic lines. If you cannot remove the rubber connectors they probably do not need to be removed. It is the loose rubber connectors that have shrunk and leak. Or.....have disconnected themselves from the hard plastic lines. Be careful that you do not kink the hard plastic lines by excessive bending. That fits right in with the connectors getting a bit tighter as they warm up.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-11-2015 at 12:34 PM. |
02-11-2015 | #23 | |
Typically (perhaps not always), vacuum leak from the secondary vacuum system does not cause high idle nor stumbling based on my experience. |
02-11-2015 | #24 |
Can you get those rubber pieces new?
02-11-2015 | #25 |
02-11-2015 | #26 |
Concur. I surprised myself when one broke in two easily when I was trying to move it off to the side while working. Luckily I was removing secondaries, so it wasn't a big deal. I guess they can get pretty brittle in that environment after a few decades.
02-11-2015 | #27 | |
Will also use tie wraps around that area.
