Old 10-27-2014   #21
edram454
edram454's Avatar
Default Re: LS1 vs.LT4 vs.LT5 vs.LS6 vs.LS7 etc. discussion continued
Originally Posted by mike100 View Post
the 2104's run 12.70's. the new 2015's are porkers and most people are getting 13.0's out of them.
but back to my 2012...
-it was a first gear roll race
-he drove it like he stole it because not his car, lol
-geared low
-vvt
I lost by half a car at 85 mph (not safe to keep going)- before I put headers, probably a 12.90-13.00 car at 111-112 at best (street tires). It was close and I had a long rev range, but it just did not have the power in that configuration. Over 100 mp[h would have turned my way. Definitely have more top end with the improved exhaust now. Anyways- we are talking 300 cubic inches in a car that weighs 100 lbs more- a lot of the mustang pop comes from the VVT 4 cam variable timing and the deep trans gearing. 1st gear is 3.66:1 ratio. fifth is 1:1. First gear is 13:1 ratio with 3:55 rear gears. Cheapest 12 second car I've ever owned. My friend was laughing his *** off too.
This is my biggest fear of these new models. I just dont find it acceptable to lose to a stock mustang while driving my zr1. I respect the coyote engine but its natural power against natural power so losing is not an option. Headers, porting and tuning are the solutions to this problem. Losing weight is another way to go. Get rid of your spare tire and carrier, cats and resonators and any unnecessary items you dont need. Keep the steering wheel and accelerator pedal.
ed ramos #3028
Old 10-27-2014   #22
spork2367
Originally Posted by Kevin View Post
i've seen lightly breathed on 5.0's go low 12s. Make no mistake that car is a serious contender
It's all relative. What do you call "lightly breathed?" I would call that a cold air intake and maybe a tune. In which case those combined aren't getting the new mustang into low 12's by a long shot.
Cold air intake, full exhaust and tune....maybe. But decent money and not what I would call "lightly breathed."
-geared low
-vvt
2012 was only 100 lbs lighter for an identically equipped car.
The 2015 is slower. But the best MT got out of the 2014 was a 0-60 of 4.3 and a 1/4 mile of 12.7. That's a best time with an above average driver and certainly not indicative of what the cars are averaging.
And again, it depends on the car. Some are simply better than others. That's not out of the range of a stock ZR1 though.
The funny thing is, we're arguing about a car that was designed in the late 80's against cars designed and built 30 years later...The new ones should be faster.
Old 10-27-2014   #23
However, in a bow towards total transparency we also are comparing a 5.0 to a 5.7L motor with similar weight. At higher speeds, I suppose the aero on the Vette also comes into play.
Old 10-27-2014   #24
spork2367
.7 liters is pretty meaningless. Especially in this day and age. HP and torque are close. The VVT is a huge factor though. That's the only thing that makes the 5.0 even remotely competitive with the ZR1. It can optimize the valve timing for ideal torque anywhere in the rpm range. Eliminate that and give it fixed valve train geometry and it would be very pedestrian.
Someone get started on some VVT heads for the LT5...
I had a Toyota 1GZ-FE...5.0 liter V12 with VVT on the intake side. 280 ft. lbs. of torque off idle...mmm.
Old 10-27-2014   #25
mike100
.7 liters is pretty meaningless....
I agree with everything you said except for the quote above... 48 cubic inches is almost the difference between the regular C6 to the LS7.
VVT is the only way to get an engine now. I'm actually disappointed that the C7 only has cam phasing and no way to change overlap. Even my other car with the LS3 feels primitive in its power delivery (thankfully 376 ci in a light car go a long ways). The mustang is nothing special, but it's a good cradle for a great engine. It is nice to have a car you don't feel bad about parking outside.
Old 10-27-2014   #26
mike100
ed ramos #3028
I put headers on right after that incident- it was already ported and chipped so it woke the hell up- best believe. I may not get another chance at a rematch, but I knew once i started dusting off c5-Z06's that the situation was looking up.
Old 10-27-2014   #27
Kevin
Kevin's Avatar
exhaust and DRs from what I hear
Old 10-27-2014   #28
edram454
edram454's Avatar
that sounds about right. I have beaten c5-z06 cars and they are very fast cars. I tried a c6-z06 and it was able to pull away slowly from me from start to finish. those ls7 engines have good torque and rev to 7 grand.. they also go 195mph. they put around 450 to the wheels. It would take a stroked lt5 to take one on.
ed ramos #3028
Old 10-28-2014   #29
Hog
Both engines have Variable Valve Timing(Coyote and LT1), the Ford Coyote has Twin Independent Variable Camshaft Timing which allows the exhaust and intake cams to be passed individually.
Much easier to do on DOHC engine than a single cam pushrod engine. Plus the smaller 5.0 required the IVCT to make power/torque, the larger GEN 5 LT1 6.2 makes more power/torque than the Coyote. It can be done though, the V10 Dodge V10 uses a cam-in-a-cam setup that allows some differentiation in the intake and exhaust valves. Ive even seen drawings of GEN 5 SBC with the same technology, but GM could reach its goals without it.
A GEN 4 LS3 would feel "primitive" compared to a GEN 5 LT1, both of which are 6.2 liters. The Direct Injection of the LT1 completely changes the character of the engine(has the torque of a GEN 4 LS7).
The LT5 with its Variable Intake Manifold Technology, was the beginning of GM's fight for upper rpm power while attempting to provide excellent low rpm torque. Way back in the 80's.
Engine tech is amazing, what we have done with the good old ICE.
Old 10-29-2014   #30
RyanChappel
Default DAMMIT!!!
Now I am seriously considering (again) sending my Z(#1929) to Haibeck for the winter.......
You guys simply cannot leave well-enough alone......
"I feel the need for (more) speed!"
RyanChappel is offline   Reply With Quote
