#21 | |
![]() Join Date: Oct 2004
I believe if I thought I had a "lean" I'd use the chassis trim dimensions in FSM section 3 as a guide and do my measurements based on those reference points. I'd do it this way if I felt I had a "straight & level" floor. The dimensions for J & K depending on year are going to be 180mm + to 190mm +. I'd cut a gage using maybe 2" PVC conduit 175mm long and then measure from the rocker to the gage and add that for a dimension. I believe it easier to measure from the rocker to the gage vs. trying to measure to the floor. You could use a metric ruler maybe 150mm long. If you measure 9mm to the gage then you would have a 184mm dimension.
To do Z and D in the FSM I believe I'd start with a 40mm gage and measure again to the gage. For Z & D I'd use the front control arm bolt and in the rear the camber bolt centers. Use the FSM dimensions only as a guide, make sure the tire pressures are equal and if you wanted to get real testy put a live body or weight in the drivers seat. I have never measured a C4 this way but I've done others in this fashion. Don't be concerned with matching the FSM dimensions, your just trying to establish the status of the chassis. With so many different wheel/tire combinations dimensions will vary widely but you would like equal/similar side to side relationship at all points. If these dimensions are far from equal/similar then you've got potential issues and maybe it would be wise to hang some gages to confirm some dimensions in the FSM using section 10-3. If you've a really lowered car adjust the height of the PVC gages. Quote:
"BATCHMAN" (Jeff) is correct when mentioning that tampering with right rear should affect left front, left rear would affect right front. Last edited by WVZR-1; 10-14-2014 at 08:13 PM. |
#22 |
![]() Join Date: Apr 2004
Stock bolts 9 and 1/4 overall and 8 and 1/2 to the cotter key hole.
Steve 1990 Steel Blue/Black #2355 1990 Red/Red #1473 1991 Quasar /Black #118 Sold 1991 Turquoise/Black #766 Parted Out 1993 Yellow/White #179 Sold 1990 Black/Gray #1361 Headers/4:10s Sold Last edited by We Gone; 10-14-2014 at 08:07 PM. |
#23 |
What I didn't do was measure right vs left (post castle nut adjustment), however, I did measure right side before/after lowering the castle nut and saw a visible and measurable difference. There wasn't a visual difference on the left (low) side...
I'll got back to Fastenall tomorrow and get the 10" bolt, maybe an 11" also and play with it. If i see any issues while i'm under there i'll address them properly. Thanks y'all Last edited by BigIke; 10-15-2014 at 01:53 AM. Reason: I'm Drunk... |
#24 |
![]() ![]() Join Date: Jul 2005
Before you go too far, try isolating the front and rear suspensions.... i.e., jack up the front equally and see if the lean to one side remains..... or jack up the rear from the diff and see if your problem is in the front.
"HIZNHRZ" had this same problem for a long time, he even switched the spring around and finally discovered that the rear lean was a front suspension problem. Regards, Mark
Mark Horner President, ZR-1 Net Registry 91 ZR-1 #2016 95 ZR-1 #21 DRM-600, LPE 385 |
#25 |
I hear that!
The bolt should show me, but i did get a result moving the right rear castle nut, and seeing the right front lower from 27" to 26.5625 and the rear went from 28.625 to 28.375. Front diff - .4375 Rear diff - .248 Now this was all takin at the same spot on the fender well, not quite scientific but a result none the less. Lowering the rear caused the front to drop more that the rear. BOLT TOMORROW ![]() When i grow up i want my junk to look like USAZR1's! PS - Mark LOVE THE HEART OF THE BEAST! Just posted a pic about it on the C4 Facebook page... ![]() |
#26 |
I'm sure you'll have it squared up soon! As for the Heart of the Beast, it's our membership's quarterly publication... I think you'd enjoy it!
Here's a peak at October's cover.....
#27 |
Given the "X" nature of height/weight you should probably check your front spring for damage. That could be the root cause. Best done on a drive-on lift or ramps - you need to see what's going on with the suspension loaded.
Good luck, - Jeff Last edited by batchman; 10-15-2014 at 12:25 PM. |
#28 | |
Any feedback is appreciated. Thanks! |
#29 | |
![]() Join Date: Oct 2013
Adjusting ride height is easy,just take the load off the spring on each side,and turn the threaded rubber bumper/adjuster by hand. VB&P offers three adjuster options: short,medium,or long. I went with the medium length and it seems to be the right choice. There is approximately 2 1/2" of adjustment available either up or down and ours are close to the middle of the range. Taking the wheels off for adjustment isn't necessary. I didn't do so. |
#30 | |
