#21 | ||
As an aside......... Marc Haibeck's Calibration AYBKG (1990) Turns both of the cooling fans on at 205 degrees F. Both turn off at 200 degrees F.
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-18-2014 at 04:00 PM. |
#22 |
I 'm looking at a stock 90 bin file AYBK, and it shows Fan 1 ON at 112C which sounds awful high for me. Fan 2 ON at 114C.
A stock 92 calibration w fans (see attached) 107C/112 under 12mph 112/114 over 12mph If the cal is stock, you may be waiting a while for fans to turn on. The gauge at the middle is 100C and its non-linear
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 03-08-2024 at 02:10 PM. |
#23 | |
![]() Join Date: Oct 2004
See if you have any information on the '92 PROM BATL (16175910) - just acknowledge I'd like the thread to continue with the OP's problem but since you mentioned '92 I thought I'd ask. |
#24 | |
I am thinking (and analog gauges are estimates) that 234 deg F is way up close to the cross hatch area. The trouble of using the AC Fans ON to cool down the engine is simply that with AC on (unless you set the interior temperature low) the AC condenser increases the heat through the radiator (additional HOT air through the radiator raising coolant temperatures).
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-18-2014 at 05:28 PM. |
#25 |
I know that the 2 broadcast codes for 92 were AZZC and BPPA. Had not heard of a BATL.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 07-18-2014 at 05:25 PM. |
#26 |
OK. Actually 3 bins for 92 AYWT, AZZC, and BPPA. All w the same values as the stock 92 bin I previously posted. 107/112, 112/114C
#27 |
#28 |
Ah! If you want to send it over I can do a compare.
#29 |
![]() Join Date: May 2013
Interesting info XfireZ51. 112Centi is 233 degrees farenheit and 114Centi is 237. I'm trying to understand why so high before fan request without AC. Is it possible maybe these bin values are modified somewhere else by other ECM inputs to lower the fan turn on request?
I have Marcs chip in my ECM and did see that the fans acted just as Dynomite says. |
#30 |
So ideally if you had access to the CTS you would ground the primary fan relay to confirm operation and then supply the ECM with values from the CTS connector to match the Delphi published specifications.
Fan runs w/relay grounded (fan is OK), fan doesn't run when supplied the required resistance the assumed problem is internal to the ECM? Here's Delphi specs for the GM 12146312 CTS: http://www.pe-ltd.com/joomla/images/...olant_temp.pdf |
