#21 |
![]() Join Date: Aug 2006
Here is the same can in black.
http://www.ebay.com/itm/Mishimoto-MM...a15017&vxp=mtr |
#22 |
Had a shot at same can but in CF like yours.
#23 | |
![]() ![]() Join Date: Aug 2005
Isn't that where the TURBOS are supposed to go? ![]() PS: GREAT wrap job on the headers! Looks as good from underneath as from on top. |
#24 |
![]() Join Date: Jan 2004
Yeah maybe on the Turbos, If I were doing Turbos they would be up front behind the radiator. I would use 1985-87 fan shroud and radiator, it gives you more room. And.... thank you.
Tony Davila (Projects) Water Meth: http://www.zr1.net/forum/showthread.php?t=19422 Exhaust cut outs: http://www.zr1.net/forum/showthread.php?t=22689 Auxiliary 12V install: http://www.zr1.net/forum/showthread.php?t=22878 Auxiliary pusher fan install: http://www.zr1.net/forum/showthread.php?t=22859 Oil Catch can Project: http://www.zr1.net/forum/showthread.php?t=20320 |
#25 |
![]() Join Date: Oct 2013
Yun,do you have any better photos of your catch can set-up?
I really like Cliff's set-up too but our 94 has the ASR to contend with,also. It doesn't have a sight tube either. Last edited by USAZR1; 07-14-2014 at 05:13 PM. Reason: Spelling |
#26 | |
Let me know which area you want pics of. Trick is to turn the "F" shaped PCV connector 180 degrees then connect "F" shaped connector to one side of the catch can. The other side of the catch can connects to the driver side PCV aluminum tube (where the "F" shaped connector use to connect to). I believe I am using 10AN lines but you can use rubber hose if you prefer. |
#27 | |
A-N lines and fittings are the only way,for me. |
#28 |
#29 |
![]() Join Date: Mar 2007
Whats on the inside of the catch can that changes the vapor fluid keep it from going into the plenum? I bought 2 off ebay, used, for $45....These appears to be custom made and came off of a race car or so the story goes...
I don't have pictures of the one on black car, but it is set up with a divided chamber; with the chamber divided horizontally by a grate that holds a filter......a hose runs from the inlet nipple to below the second part of the chamber. the oil vapor then must come up through the filter before exiting the outlet nipple the one below is even more interesting, the oil must return through a series of baffles to get from the entry nipple to the exit... ![]() ![]()
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 07-14-2014 at 11:30 PM. |
#30 |
Lee,
Those are nearly identical to what I got. As the oil vapor cools it drops out of suspension to the bottom of the can |
