Old 06-25-2014   #21
WVZR-1
Default Re: I think I lost my alternator today, or its real close to crapping out. Belt #?
You need to establish a "plan" for the charge wire. You're doing a 200 AMP product and you mentioned some accessories so you've got to do something with the "charge wire".
I believe PowerMaster over does it maybe a bit but here's their thoughts and it is their product.
http://www.powermastermotorsports.com/charge_wires.html
It will be interesting if you post back with real charging numbers at the RPM's that they claim for their product. You mentioned having their product in the past and I don't know that I've heard many negative comments regarding it.
Old 06-25-2014   #22
alwayscode390
That makes sense and is definitely something I overlooked.
I wonder what gauge our stock charge wire is? Im hoping 6 gauge since our stocker is 124 amps, and that's what is recommended by Power Master, but it may be 8 gauge too.
Thanks for looking out for me WVZR-1 ---
alwayscode390 is offline   Reply With Quote
Old 06-25-2014   #23
WVZR-1
I believe you'll find 8M but 8M is equivalent of 8AWG so I'd guess to actualy optimize the system you do need to look into it.
Old 06-26-2014   #24
alwayscode390
How long of a charge wire am I going to need? They sell them from 2ft to 12 ft.
Is the charge wire tucked through the engine where it is going to be hard to replace the stock one and run a new one ... or is it pretty much from the alternator to the battery around the engine block?
I found a 6 gauge kit that's 5ft long ... does that sound like the one? ---
Old 06-26-2014   #25
Schrade
Bunch of alternator pics here http://www.zr1.net/forum/showthread.php?t=21259
Removal, breakdown, CS144 schematics, FIRE!!!, etc, starting post 141 - 159, 186 - 209
Sure is a bunch of 'Click n Scroll' - what a pain.
Old 06-26-2014   #26
WVZR-1
Do the wire "local" - you should have no issues accomplishing a replacement using just local options. The OE also has a fusible link so that needs to be considered in the "how do I replace"? An audio shop should be able to provide you with a proper fuse and holder for the charge wire. You won't find "fusible link" material for 6ga wire so the wise choice anyway would have been a fuse. How many AMP? I don't know that there's simple way to calculate the needs and discussions regarding such are certainly entertaining.
You could eliminate the charge wire from the battery jump block and send it directly to the battery using a different battery bolt/terminal combination. That's how we did some fleets with auxiliary lamps and power requirements. Again an audio shop or a fleet body builder in the vicinity could help you.
Here's a link to a MEGA holder and boots.
http://www.vteworld.com/content/elec...a/megafuse.php
here's ANL and this is what I believe you would find in an audio shop as a rule.
http://www.vteworld.com/content/elec...nl/anlfuse.php
This holder by LITTLEFUSE should be available at any auto parts store. ANY of them!
http://www.littelfuse.com/products/f...er/298900.aspx
This is the auxiliary bolt like we used for fleets. I've done hundreds of them. This is NOT where to buy but there's an installed image and also one of just the product:
http://www.prime4x4.com/shop/OffRoad...AccBolt001.htm
Old 06-29-2014   #27
When I replaced the belt a few years ago the first belt I had,an OEM part would not go on the car regardless of what I tried.I think I ended up using a Gates belt.
Old 07-03-2014   #28
alwayscode390
Arrow Re: I think I lost my alternator today, or its real close to crapping out. Belt #?
Do it yourself if you like. There will be the OE number on your original either 1101238 or 1101849 - there's little difference, maybe only the bridge rectifier.
My stock one is a number 849, 120 amp version.
I got the Powermaster installed, I dont recommend it unless you are dead set on a 200amp alternator ... it took some modifications ---
