Old 06-06-2014   #21
WVZR-1
Default Re: Help! Unable to rev past 5000
They mount next to the frame and the battery and control the Secondaries in concert with the DIS. The Quad drivers come in pairs and command 4 injectors each of the secondaries hence the name "Quad" I forget which year no longer has them but it might be 93 and up with the 405HP release.
I've never heard the term "quad driver" except from Daryl and I never knew what the he!! he was talking about. All years have the "pair" of injector drive modules, on the later cars they're mounted on the rear of the RH wheel-house on a multi relay bracket.
Clint - your '94 should be on the RH wheel-house
Quad driver failure has specific error codes when GM ECM utilizes them and they're built into GM ECM circuitry. Do these modules serve a similar function? Don't know. Now I do know what Daryl has been referring to though.
Where the terminology came from? I have no idea.
There's been many conversations regarding quad-drivers through the years and Tyler mentions ECM, it's been mentioned they were on the PROM - all sorts of silliness.
Old 06-06-2014   #22
I learned this term from a few members quad was used as each module controls 4 injectors. However I posted both terms to not confuse anyone. Your right however after a little research all ZR-1s have these modules but as stated they moved. GC
Old 06-06-2014   #23
Originally Posted by chriskinzel View Post
I will be changing crank sensor and fuel filter tomorrow. I don't know what to do about the quad drivers. Keep your fingers crossed!
Chris
Chris I forgot to mention a few of the Crank Position Sensors out there had a bad batch for a while. The magnet was installed backwards. When you pull the OEM unit match up the replacement unit tip to tip. If they attract the replacement unit is bad. They should repel each other if the magnet is installed correctly.
Old 06-06-2014   #24
chriskinzel
chriskinzel's Avatar
I will be sure to verify magnet orientation before anything is replaced.
Chris
chriskinzel is offline   Reply With Quote
Old 06-06-2014   #25
chriskinzel
Update
Decided to drive the car to dinner tonight. The miss is now starting anywhere from 2500 to 3500 rpm. I revved it in out of gear until it started to miss. It was at 3000 rpm. Fuel preassure was 48psi. Dark smoke coming from the exhaust. Tach had about a 1000 rpm swing. This is with no load on the engine. I will still be replacing the crank sensor and fuel filter tomorrow.
Chris
Old 06-06-2014   #26
Update
Chris
Well here's my thoughts on that. I did not suspect the crank sensor because it was not having a problem until the 5k rpm range. If the crank sensor was bad it would have problems at all rpm ranges. Sounds like you could be on to something. GC
Old 06-06-2014   #27
Demps
Demps's Avatar
PROM installed correctly? Have a good ECM to compare?
Ted
Demps is online now   Reply With Quote
Old 06-06-2014   #28
Ted
Yep Ted that's a possibility as well
Old 06-06-2014   #29
chriskinzel
Ted
I think the PROM is installed right. I don't have any other ECM to compare with. I will have more results in the morning. Too hot now to mess with.
Chris
Old 06-07-2014   #30
Pete
Pete's Avatar
Update
Chris
Sounds like secondaries not coming on or shutting down.
Check codes.
Check secondary vacuum solenoid under plenum make sure it's pluged in.
Also make sure MAP sensor under ECM is pluged in.
When secondaries don't work it shuts her down at 3k rpm(like rev limiter)
Maybe recheck chip program sometimes the best can miss something.
Do not throw parts at it.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
