#21 | |
I thought I was the first to mention the "service slip-yokes" supplied by most aren't any better than a 100k used one. I've a slip-yoke that's been used many times for correct fixes that only requires the use of a 1330/1310 conversion joint and the removal of 30mm from the end. It's got the correct major/minor spline dimensions. Still pretty readily available. |
#22 | |
![]() Join Date: Dec 2003
Jerry Downey [I][COLOR=#ff0000][B]JERRYS LT5 GASKETS & PARTS[/B][/COLOR][/I] [URL="http://www.jerrysgaskets.com"][U][COLOR=blue]http://www.jerrysgaskets.com[/COLOR][/U][/URL] 1994 [B][I]ZR-1[/I][/B], Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 06-07-2014 at 01:15 PM. Reason: correct misspelling |
#23 |
![]() Join Date: Nov 2011
On cheap option is to get a friend to drive behind, to the left and right side while you drive at the bad speed. Have him (or her) look at your wheels. Look for bent rims, or tire bouncing. Anything out of the normal. This is basically free and maybe you might find something. Good luck.
Chris
91 ZR-1 Red on Red #922 |
#24 |
![]() Join Date: Feb 2014
I had a similar issue with my 90. Went nuts trying to figure it out. Changed everything you could think of, including two sets of wheels, two sets of tires ,a steering rack. Turns out it was a right front shock that would not compress. It would expand but would only compress to its nominal ride height. Low mile car, so it probably stuck in that position. Two new front shocks on, problem solved.
#25 | ||
I like the observation while driving and I often see cars on the highway that I can't image how they tolerate it inside the car while watching wheel/tire reaction to the pavement. I believe you need to do the observations and let someone else do the driving. You just pick the speeds, I'd think 70 MPH should show all. Good pavement a necessity. |
#26 |
![]() Join Date: Apr 2013
Yeah that I think I will do if this doesn't fix it. Plenty of freeways around here I could do that on.
I was going on an hour roadtrip today to a show - but there is a giant green/orange/red blob on the weather radar moving across the state. SO it will sit in the garage til tomorrow. ![]()
#27 | |
I have not found hub play to lead to a vibe - but it does lead to failure. A new record for me this weekend, about 12 and 1/2 miles. 3rd run in my national event. Sigh, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
