05-19-2014 | #21 |
Re: 4.10 gears...not what I expected.
Chris,
Very interesting that you don't notice a difference with the 4:10's. Most notice a tremendous difference.... Can you get the model # of dana spicer they installed? Also did they install a speedo correction gear? (did you get it from Marc?) And if they did install the speedo gear, how accurate is it? David |
05-19-2014 | #22 | |
I've gotten a little more used to it over the weekend and frankly, I sort of like the new "personality" of the car. The upper gears are more usable and the car moves away from a stop more easily, which is great. Again, this has to do with having unrealistic expections, more than anything else. Overall, I'm more surprised with the result than disappointed. |
05-19-2014 | #23 | |
Yep, I could get you the number of the gearset, I still have the box at home. I also had Marc's correction gears installed. It's different, there's no doubt. It does rev quicker and the upper gears are more useful. As I've said in other replies, I really think this has more to do with unrealistic expectations than anything else. It accelerated hard before and I expected this to increase that sensation but it didn't. It really just feels more high-strung, if that makes sense. |
05-19-2014 | #24 |
You should be running out of rpms in 3rd around 100+mph vs 120+mph with 3.45s, I'm around 115mph with 3.73s
05-19-2014 | #25 |
http://www.carcraft.com/techarticles...s/viewall.html
Geared Up For Speed Hot Rod did a test of gear ratios and converter sizes (smaller equals higher stall speed) versus engine rpm and quarter-mile times for their June '95 issue. We helped with the testing, so we don't feel too bad about ripping them off and reprinting the numbers here. The car used was a small-block Nova with 26-inch-tall tires. We tried four gear ratios with two TCI converters, and here's what we found: Same Car.... 3.50 gear 13.40@102.59 4.11 gear 13.18@102.81 Read more: http://www.carcraft.com/techarticles...#ixzz32C7fPvaZ
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 05-19-2014 at 05:18 PM. |
05-19-2014 | #26 |
First let me say, I could take or leave the 4.10s....I would rather have $1500 in motor mods. That being said the 4.10s have:
*Less Bog on the launch *Better accel from a roll... I was in my 92 Zr-1(4:09) when two guys in Ducatis kept flying up on the back of the car, then backing down(we were out in the country)....after about 3 three times, the one went to haul *** past me, and when he got up close to the car I punched it....the car pulled with the bike.(it was a smaller Ducati) When we got to a stop they said they were surprised at how well the car pulled compared to the bike....to me with the 3.45 there would have been a "lag"...with the 4.09 its immediate kick in the pants throttle response.
05-19-2014 | #27 | |
05-19-2014 | #28 |
I had a guy do a 2.59 to a 3.45 swap on an LT-1 I did head work on...after driving my 3.45 and 4.11 cars and then into the LT-1 it seemed slow....however when he got in it....he was amazed. You are right sometimes its just perspective and in your mind/expectations.
05-19-2014 | #29 |
A chassis dyno won't take the gear ratio into account except that some gear selections may have more friction than others. Lets say your engine makes 300 lb/ft of torque and you run it through a 3.08 diff. The axle will see over 900 lb/ft of torque (and of course 3 times slower rpm for a conservation of energy). The chassis dyno won't read 900 lb/ft, it's a separate system with its own diameter and speed calculation. All you get is the engine torque minus the frictional losses (and whatever other fudge factors are in the mix for the dyno).
I always felt individual trans gearing would always be more useful than just the final drive, but that is not too practical in production transmissions. Take a look at the MT-82 trans in the new mustangs... 1st gear is nearly 4:1 and the 1:1 gear is actually 5th (not 4th). That's about 1/2 the reason those new Mustangs scoot so well in the 1/4. I wish the ZF had tighter ratios sometimes. It is a time-to-distance mod, not so much a seat-of-the-pants mod. I'f I had the budget, I'd do 3.73's myself. |
05-19-2014 | #30 |
.22 @ 1/4 mile, I like it
